PROBLEM WITH SHORTCUT,FAILED TO RUN
G
Guest
Guest
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
I CAN NOT OPEN ANY SHORTCUTS,OR GET PROPERTIES FOR MY COMPUTER OR ANY OTHER
FOLDER OR PROGRAM. CAN'T RUN MSCONIG OR REGEDTIT: THE MESSAGE COMES WITH
"PROBLEM WITH SHORTCUT. THIS INTERNET SHORTCUT CAN NOT BE OPENED BECAUSE
FAILED TO RUN". I HAVE WINDOWS98 AND THIS JUST STARTED FEW DAYS AGO. PLEASE
HELP!!
JANEK
G
Guest
Guest
Please use upper and lower case letters when posting--all CAPS are hard on
the eyes.
See if the shortcut fix will do it:
http://home.satx.rr.com/badour/assets/images/LnkW98.zip
Regards
Ron Badour, MS MVP for W98
Tips: http://home.satx.rr.com/badour
Knowledge Base Info:
http://support.microsoft.com/default.aspx?pr=kbinfo
"JANUS" <JANUS@discussions.microsoft.com> wrote in message
news:46C3524A-E15F-4F85-B7E4-E5BFCD8B11F9@microsoft.com...
>OTHER
> PLEASE
> HELP!!
> JANEK
G
Guest
Guest
Thanks for your quick response, but when i tried to conect to to sugested
link provided by you I received the same warninig "Problem with shortcut".
Can you provide me with some additional solutions??
JANEK
> the eyes.
> Regards
> >OTHER
> > PLEASE
> > HELP!!
> > JANEK
G
Guest
Guest
Duh, pretty dumb suggestion, right ? <G>
My old email address is: rbadour at satx dot rr dot com. Remove the first
letter (r) of the email address and send me a request for the LnkW98.reg
file--I'll mail it to you.
Regards
news:8950C4B7-B9C2-48ED-8748-9C9EA7347386@microsoft.com...
> shortcut".
> JANEK
>> on
>> the eyes.
>> Regards
>> >OTHER
>> > WITH
>> > BECAUSE
>> > PLEASE
>> > HELP!!
>> > JANEK
G
Guest
Guest
I did receive the lnkw95 in your email but it was blocked permamently by some
system, i was thinking you were mailing it to me in the us mail. i do not
know what else i can do to get that link.reg
Thanks for your help.
Jan
JANEK
> Regards
> > shortcut".
> > JANEK
> >> on
> >> the eyes.
> >> Regards
> >> >OTHER
> >> > WITH
> >> > BECAUSE
> >> > PLEASE
> >> > HELP!!
> >> > JANEK
G
Guest
Guest
It is an electronic file--it cannot be mailed in the US Postal service.
Tell me what happened that it was blocked any maybe there is a way around
it. If there was an error message, post that verbatim.
Regards
news:4744A30B-A00A-41C5-82C6-D18E9BC3C6E6@microsoft.com...
>some
> not
> Jan
> JANEK
>> first
>> Regards
>> > sugested
>> > shortcut".
>> > JANEK
>> >> hard
>> >> on
>> >> the eyes.
>> >> Regards
>> >> >ANY
>> >> >OTHER
>> >> > WITH
>> >> > BECAUSE
>> >> > AGO.
>> >> > PLEASE
>> >> > HELP!!
>> >> > JANEK
G
Guest
Guest
The message was: Hotmail has permanently blocked the following potentially
unsafe attachment(s): LnkW98.reg (< 0.01 MB) More Info...
Ido not know what to do with it here??
wiating for additional help.
Jan
JANEK
> Regards
> >some
> > not
> > Jan
> > JANEK
> >> first
> >> Regards
> >> > sugested
> >> > shortcut".
> >> > JANEK
> >> >> hard
> >> >> on
> >> >> the eyes.
> >> >> Regards
> >> >> >ANY
> >> >> >OTHER
> >> >> > WITH
> >> >> > BECAUSE
> >> >> > AGO.
> >> >> > PLEASE
> >> >> > HELP!!
> >> >> > JANEK
G
Guest
Guest
With Badour's permission, here is...
Copy everything between the START & END lines into a text file named "LnkW98.reg". You may use Notepad. Enclose the name-- "LnkW98.reg"-- within quotes in the Save box to prevent the attachment of ".txt" to the name. Then, click it to merge it's contents into your Registry.
........START after this dotted line...........
REGEDIT4
[HKEY_CLASSES_ROOT\.lnk]
@="lnkfile"
[HKEY_CLASSES_ROOT\.lnk\ShellNew]
"Command"="C:\\WINDOWS\\rundll32.exe AppWiz.Cpl,NewLinkHere %2"
[HKEY_CLASSES_ROOT\lnkfile]
@="Shortcut"
"EditFlags"=hex:01,00,00,00
"IsShortcut"=""
"NeverShowExt"=""
[HKEY_CLASSES_ROOT\lnkfile\CLSID]
@="{00021401-0000-0000-C000-000000000046}"
[HKEY_CLASSES_ROOT\lnkfile\shellex]
[HKEY_CLASSES_ROOT\lnkfile\shellex\IconHandler]
[HKEY_CLASSES_ROOT\lnkfile\shellex\DropHandler]
[HKEY_CLASSES_ROOT\lnkfile\shellex\ContextMenuHandlers]
[HKEY_CLASSES_ROOT\lnkfile\shellex\ContextMenuHandlers\{00021401-0000-0000-C000-000000000046}]
......END before this dotted line........
........include the empty line............
NOTE: The above is in MIME format to avoid breakage. The main line in danger of breaking is...
....That is all one line with no space, as is every line up there that is between solid brackets... [].
By default, when a ".reg" is clicked, it will Merge into the Registry.
To alter the default behavior: "START, Settings, Folder Options, File
Types tab". Scroll to & click "Registration Entries", click the "Edit"
button, select "edit" in the window & click the "Set Default" button.
Now, when you click a ".reg" file, it will open in Notepad for
examination. To merge it into the Registry, R-Clk it & select "Merge".
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
"JANUS" <JANUS@discussions.microsoft.com> wrote in message news:4744A30B-A00A-41C5-82C6-D18E9BC3C6E6@microsoft.com...
| Jan
| JANEK
| > Regards
| > > shortcut".
| > > JANEK
| > >> on
| > >> the eyes.
| > >> Regards
| > >> >OTHER
| > >> > WITH
| > >> > BECAUSE
| > >> > PLEASE
| > >> > HELP!!
| > >> > JANEK
G
Guest
Guest
I don't use Hotmail. Look through it's Help menus for "Attachments". I
do know...
"OE, Tools menu, Options, Security tab" has a box to uncheck... "Do not
allow attachments to be saved or opened that could potentially be a
virus".
HOWEVER, doing so (as I have done off/on) will entail a measure of
risk-- NOT that Badour, himself, is a scoundrel necessarily.
PCR
pcrrcp@netzero.net
news:4105616F-6F8F-4DCB-B010-E144BA54EB37@microsoft.com...
potentially
| Jan
| JANEK
service.
around
| > Regards
permamently by
| > >some
i do
| > > not
| > > Jan
| > > JANEK
the
| > >> first
LnkW98.reg
| > >> Regards
to
| > >> > sugested
with
| > >> > shortcut".
| > >> > JANEK
are
| > >> >> hard
| > >> >> on
| > >> >> the eyes.
| > >> >> Regards
COMPUTER OR
| > >> >> >ANY
| > >> >> >OTHER
MESSAGE COMES
| > >> >> > WITH
OPENED
| > >> >> > BECAUSE
DAYS
| > >> >> > AGO.
| > >> >> > PLEASE
| > >> >> > HELP!!
| > >> >> > JANEK
