Question Problem with sodimm laptop memory
Apr 13, 2019
41
Hi, i installed 2×2GB PC-6400S sodimm memory on my laptop and it doesn't work.When i put one of a memory it works.Also i put the 1×2GB with an 1×1GB memory and it works again.Do you know what is the problem?
41
Did you check the laptop support site to see what the memory config it can work with? Check for a BIOS update if it will work with that you are trying?
I looked for my laptop specs here and says that supports ram size up to 4gb.Also, i updated the BIOS but the problem still occurs.When loading the windows it shows me a blue screen with the message "DRIVER_IRQL_NOT_LESS_OR_EQUAL".
