problem with software installation
bs
13
Archived from groups: microsoft.public.win2000.group_policy (More info?)
hi there,
i want installation software with GPO, but i can't because my changes is not
applying.
so, what i must enable to use GPO and installation software from .msi
package?
GPO partly working; i can set home page in IE, policy for password working
too.
regards,
Bogdan.
G
Guest
Guest
"BS" wrote:
> hi there,
> changes is not
> applying.
> from .msi
> package?
> password working
> too.
> regards,
> Bogdan.
Hi,
For Group Policy Software Installation to work here is what you need.
1> Make sure DNS is setup correctly
http://www.sd61.bc.ca/windows2000/dns.htm
2> Make sure GPO is on an OU that contains the "Users" (for the User
Configuration" to work. AND/OR "Computers" (For the computer
configuration" to work.
3> Make sure the Software Package is running from an UNC Path eg.
\\myserver\myinstallpackage.
4> Make sure that you assign to Users who have Admin access to install
or if not then assign to Computers.
5> If assigned to Computers, then make sure "Domain Computers" group
has at least Read access to share listed in #3.
6> Make sure the MSI is an "auto installing MSI" or if not, then has
an MST file you have customized to make it "auto installing".
Cheers,
Lara
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Group-Policy-problem-software-installation-ftopict545422.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1724218
G
Guest
Guest
"lforbes" wrote:
> Hi,
> you need.
> the User Configuration" to work. AND/OR "Computers" (For the
> computer configuration" to work.
> eg. \myservermyinstallpackage.
> install or if not then assign to Computers.
> group has at least Read access to share listed in #3.
> then has an MST file you have customized to make it "auto
> installing".
> Cheers,
> Lara
Hi!
I too have had problems getting software deployment to work through
Group Policy. It works just fine when setting it up by user, but have
had no success getting it to work by computer.
I have following all of your steps listed as well as done some pretty
extensive troubleshooting but it just will not install. I know the
policy is being applied because other parts of it are taking effect.
I have a test OU setup with the computer account in it for my test PC.
I have setup the policy to install by computer (assigned). The PC
boots up normally with no sign that software is being installed, and
in fact it is not being installed.
Does anyone have any other ideas, suggestions on why this isn’t
working?
Thanks!
G
Guest
Guest
"lfairban" wrote:
> Hi!
> through Group Policy. It works just fine when setting it up
> by user, but have had no success getting it to work by
> computer.
> pretty extensive troubleshooting but it just will not install.
> I know the policy is being applied because other parts of it
> are taking effect.
> test PC. I have setup the policy to install by computer
> (assigned). The PC boots up normally with no sign that
> software is being installed, and in fact it is not being
> installed.
> isn't working?
> Thanks!
Hi,
That is indeed weird. Have you checked the event log? I had an issue
before I put the Domain Computer group access to the share but after
that everything is fine.
However, it will only do software that doesn’t require any input or
has an MST file for it. I use it for Adobe Acrobat and Office which
have the ability to create MST files and also any software produced by
MS like the Shadow Copy Client, and the Power point viewer. All
install without a problem. I have even created an MSI for IExplorer
and deployed IE SP1 via Group policy assigned to computers.
Make sure you haven’t removed the SYSTEM=Full control group from the
local HD’s.
Check the event logs. Mine, even when it failed, actually started with
"installing managed software".
Cheers,
Lara
