Question Problem with start memory at 6000mhz Kingston Fury Beast 2x16gb kit CL 36-38-38.
Jan 24, 2024
5
Hello guys!I'm a big fan of Tom's Hardware and I think only you can help me..I have a mainbord Asrock X670e Steel legend. CPU 7800x3d and RAM Kingston Fury Beast EXPO/XMP 2x16gb 6000mhz 1.35V. When I run the ram from the bios to 5600mhz on EXPO At voltage 1.25 by default the bottom starts and I have no problem, but when I try EXPO 6000mhz on 1.35v I get 3 system restarts and ram starts at 4800mhz. Please help! Thanks in advance!
update bios, try again
I try bro,only sometimes at bios 1.28 can start with 6000mhz,but not working good system,now use the latest bios 2.02 I have doubts that the voltage is low for 6000mhz, but I prefer to hear a competent answer with specific settings if someone has had this problem.
yes i also suspect the voltage is to be the issue. i haven't experienced this, so i cant confirm, but near factory default voltages wont be stable as most XMP profiles use 1.5v ish
I also understood something like that, but I would be very grateful for a screenshot, if someone could give me specific settings so I don't mess something up
Hello again ! I tried the ram one by one. Each one starts at 6000mhz on A2 slot and on B2 slot. I rotated both of them on A2 slot and B2 slot, I tried bios 1.30,1.40 2.02 no problem to start it at 6000mhz, but only one tile when I put both and I reach a maximum frequency of 5600mhz. At the moment, the bottom of bios 2.02 started with both at 6000mhz, but I think that the system is stable and it is a matter of time to reset it to 4800 again....
