[SOLVED] problem with system but I am not sure what is cause
technicaltutorials84
Commendable
Dec 20, 2018
33
Hello friends
I have already ask this question in different category but not received satisfied answer.
Problem is that when i use load on system with my gpu (gtx 750ti) my psu failed (Local brand). I last time my display IC was burned.
I am confusing because I don't know that is this my gpu fault or my psu failed or my ram casue.
I am using three different types of ram i.e.
Samsung 1600 mhz
Consistant 1300 mhz
and some other 1600 mhz
these all work on different cas latency
is it possible the ram also cause of system failure
So, what should i do? Change only psu, change only ram (Kit) or change both
my system is
i5 3330
motherboard H77m d3h
8gb ram (according to above)
500gb barracuda
psu non branded
thanks
