I made a new sistem with a M5A99FX pro 2 from asus with a fx 8350 stock cooler, a gtx 970 amp extreme form zotac (the frist one the one with leds and dual conectios to the power supply of 8) 8gb ram gskill 4x2 (it was from my old sistem) and a power supply OCZ Fatal1ty 750 w (also from my old system). Then i bougth 16gb ram 4x4 kingston hyper x fury and the problem started. frist i thougt memorys was broken, so i did memtest 1 by 1 and all give me btw 50 and 56 errores in test 2, 3 and 4, and if i test all together the made an orgy of errors until it restarted. Well i change memory in the store, and when install all again and make the memtest it get the same amount of error.
At that pint i thougth it was the mobo that was broken. Since i went to a frind house with the same mobo and the memorys didnt made a single error.
At last before i call asus i made new test but this time i change the gpu for a hd6950 and disconected both hd wd black 7200 and de dvd rw. This time the test was succesfull 0 errors. I change the gpu again for the GTX 970 (this version have an oc chip that you ahve to conect to a usb port from the mother to work) with th oc uncconected and again a succesfull memtes. I pluged the OC chip and, again a succesfull test. Last time i pluged both hd and the dvd rw and the memtest made an error fest.
So i cant managed to get a power supply to probe it, so i have that both "thories" that is the power supply or is the mobo. I cant prove the Power supply since i dont know how to do it properly.
So what is the chance that the mobo dont work properly? Or is the power supply that for some reazon isnt working properly?
Thz in advance
Thz in advance
