Hi guys, I bought a new PC before 3 months ago with these specifications:-
Intel Core2Duo E6750
Asus Commando motherboard
2GB RAM DDR2
120 HD + 300 HD SATA
Nvidia geforce 8600 GTS
Windows Vista Home Premium 32bit
I build the pc and I flash update the BIOS to support the 1333fsb, installed the OS and everything was working fine.
The problem is that I after a month or two I start up the PC and I found this massage at the bottom before starting windows.
"CMOS checksum Bad
Overclocking failed! Please enter setup to re-configure your System
Press F1 to Run the SETUP
Press F2 to load the default values and continue"
First I am not doing any over clocking
I press F2 to load the default values and the computer starts without any problems.. Yesterday it happened again, this time I tried to run the setup to check the BIOS configrations (everything was fine and far as can see) exit it without changing anything and it load windows without any problems. Today it happened again also , I dont know what to do any more. So please guys HELP.
And thank you in advance.
Note: Before posting this topic I made an update to the BIOS, in case that this problem may go away, but it is still the same.
2GB RAM DDR2
"CMOS checksum Bad
