G
Guest
Guest
Archived from groups: alt.video.dvd.tech,rec.video.desktop (More info?)
I've made some captures with my Hauppauge PVR-350 using the DVD Long
Play mode. 6.2Mbits/sec MPEG2. I put them on a DVD data disk and my
player with play that file and it looks nearly flawless, but I want to
put it in a proper DVD file structure so it will work on any player.
After running it through DVD author the resulting video is lower quality
than the original, there's "jaggies" on the endges of objects and there
seems to be more artifacts. Now since this was a DVD compliant file to
begin with, and only 4GB in size, can anyone tell me why TMPEGEnc has
mangled it and if there is a way to prevent that?
____________________
Remove "X" from email address to reply.
