Question Problem with triple monitor mount ?
pirate_tat87
27
Hello,
I am in a bit of a situation.
The setup I have is 3 x Gigabyte Curved Monitors.
1) One of them is a 32"
2) The other two are 27"
The center monitor is currently 32" and the left and right side monitors are my 27" monitors.
The monitor mount that I am using is by huanuo
https://www.huanuo.com/products/hua...h-gas-spring-swivel-tilt-rotate-clamp-grommet
However my two side monitors are physically overlapping behind my center monitor by about half an Inch,
Is this normal for curved monitors or is it this because i have different size monitors, or should I invest in some alternative monitor mount?
As you can see in the image that I took
According to the Huanuo mount link that you provided the mount supports a combined monitor length of 85".
Likely a generous, "best case", ideal determination.
Your monitors:
27" + 32" + 27" = 86"
And yet they are somehow showing/implying the use of three 32" monitors totaling 96" ???
What you will need to do is start with a straight in-line set of measurements and then gradually "curve" the three monitors to determine how far you can go without any overlap.
Or be able to accept some amount of overlap.
If it does not work out as you require then you will need to look for alternative monitor mounts.
Double check all measurements and specs. Read the fine print. Take a critical look at all images and diagrams.
