Hello guys, i have changed my CPU R5 1400 to a R5 2600 and i heard of people getting it up to 4.2GHz (that's not my goal). But i am struggling to know what's the mistake i make while overclocking with ryzen master.
Currently i can keep it up at 1.35v and 3.9GHz but someone said i shouldn't have the volts at 1.35 but at 1.25 or something like that. Indeed when i first installed the R5 the voltage was like 1.12 or something like that, i don't remember exactly. But i tried using 3.9GHz @ 1.25v and it passed the ryzen master's stress test but it crashed while running cinebench r20.
My temps are normal (if not under heavy load like cinebench, otherwise it gets almost at 80ºC) idle are 44-47ºC (where i live it's considerably hot since it's summer so it's not something i will worry about) and while gaming it doesn't reach 65ºC. And if it does, it never gets above it.
My setup is
CPU: Ryzen 5 2600
GPU: MSI GTX 1660 TI Gaming X
PSU: Nox Urano 650w 80+ bronze
MOBO: Asrock AB350m Pro4
RAM: Corsair LPX 16gb 2x8 2400mhz
Thank you in advance
My setup is
CPU: Ryzen 5 2600
