Hello
the problem i m havisg is this:i just bought a sapphire radeon 6850 to upgrade from my radeon 5770.After installation everything seemed ok and the fist day all run smooth.However when i turned on the pc on the next day i started having blurry spots all over the screen-square shaped and lines- which became more and more while i moved the mouse cursor and finally the system would freeze.i tried many restarts and at times i got a blue screen stating an error concerning the installation of new hardware,but it only appeared for moments so i couldnt note what error it stated Now i m running again on my old vga.Any ideas?the rest of my system: AMD phenom2 X4 965,ASUS Crosshair Formula III,8GB ram ddr3-133,WD 1TB, windows7 64bit,PSU thermaltake 600W
thank you in advance
ps1:when i installed the new one i didnt removed any drivers of the old one.thought there might be compatibility since they r both same manufacturer-company-type.could that be the problem?
ps2:my motherboard supports pci express 2.0 while the new card is 2.1..i think that this isnt an issue right?
