I purchased an EVGA Z390 FTW motherboard in December 2019. I had occasional problems with Windows crashing and not being able to restart. The issue became more frequent so EVGA sent me a new motherboard. It worked for a few days and the same problem began again. They said the board they sent me must have been defective so they sent me another but the problem wasn't solved. I replaced the I9-9900K cpu which took a month before Intel agreed to replace it. Then I bought a new power supply. and then the memory. All this happened over a period of months.
Someone on a forum suggested I try installing Windows on a different hard drive so I tried that yesterday. It seemed to install okay but when Windows started updating it locked up and wouldn't restart. I tried again today Its been installing for an hour now and its only at 6%. This is my fourth try and and I'm sure it will shut down before it finishes just like the other times. Sure enough, just got this error message: "Windows cannot install required files. Make sure all files required for installation are available and restart the installation. Error code: 0x8007045D".
I've been building systems since 1992 when I went to school for it and I have never has so much trouble. Is there a known issue with EVGA Z390s? EVGA has always been one of my preferred brands but I'm starting to change my mind. Has anyone else had issues with EVGA's Z390? I built an identical system in August, only with a Gigabyte Ahorus Z390 mb and its working fine. My plan was to buy a RTX 3080 for this computer and put the 1080 in the computer I built in August. Oh well, maybe next year.
Jerry
System specs:
EVGA 123-CS-E397-KR LGA 1151 (300 Series) Intel Z390 SATA 6Gb/s ATX Intel Motherboard
Intel Core i9-9900K Coffee Lake 8-Core, 16-Thread, 3.6 GHz (5.0 GHz Turbo) LGA 1151 (300 Series)
EVGA CLC 240 Liquid / Water CPU Cooler, RGB LED Cooling 400-HY-CL24-V1
CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800)
Gigabyte 1080 GTX 8GB
Cooler Master HAF XB EVO Test Bench and LAN Box Computer Case
(2) WD Blue 500GB PC SSD - SATA 6 Gb/s 2.5 SSD
WD Blue 1TB PC SSD - SATA 6 Gb/s 2.5 SSD
Intel 1TB 660P NVMe M.2 Internal SSD
EVGA 850W psu
Jerry
System specs:
EVGA 850W psu
