Problem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
K so i have window 7 32bit and I want to get window 7 64 bit.
From my understandings..i have to do a clean install.
I backup my files and I am getting ready to wipe out my harddrive. The problem is i cant boot from the cd drive. I made my cd drive first priority in BIOS boot settings.
Any helps?
Computer specs :
1tb hd
6g ram
asus p6t
crossfire hd 4870
i7 920
I'd be surprised if a system sporting an i7 processor has a CD drive and not a DVD drive (can you even buy plain old CD drives nowadays?). I suspect that your second point is the relevant one. Or possibly, as Herr_Koos suggests, it's not a genuine, bootable Microsoft DVD.
I make cd room my only boot option and still doesnt work.
There are is no adjust to boot sequence list.
I would also like to mention that. i build the computer
Make sure that the SATA cable to the drive is connected at both ends. I assume the power cable is connected, since you were able to insert a DVD in it (eject). May want to try replacing the SATA cable or try a different SATA port on the mobo.
