Problem...
G
Guest
Guest
Archived from groups: alt.games.the-sims-2 (More info?)
None of the objects I've downloaded are loading into the game. I've
reinstalled the game and still nothing. Anyone out there know what to do?
"Samantha Leigh Tully" <nx-01@NEVERMIND.com> wrote in message
news:26Kdnb9e1901JnHcRVn-sw@rogers.com...
Do you have "Custom Objects shown in Catalog" enabled in the game options?
Do you have the color enabler from the simPE site? You need that in order
to see some of the recolored furniture.
Also, make sure you are looking in the right spots in the game.
Floors and walls do show under whatever category the creator put them in.
For objects, you have to click the type of object, then choose from the
flyout. User-made objects will have a star (asterisk) on them.
You may have to scroll in the dialogs to see all the items.
Same goes for makeup and clothes, as far as the star and the scrolling.
Ready made sims will be in the area where you create a sim, you just need to
click the button for a ready-made sim after you decide the family name and
male or female, adult, etc.
stupid question ;-)
Did you install them properly ? unpacked them ?and then did get the
installer file ?
all downloads ? houses ,walls floors ,clothes ???
greetings
"Samantha Leigh Tully" <nx-01@NEVERMIND.com> schreef in bericht
Yep. Did everything and nothing comes up. No floors, walls, objects..
nothing I downloaded is working. I rechecked the files and they are there,
just not in the game.
"Drs. muts" <opzouten@sukkel.nl> wrote in message
news:353ssdF4ikeklU1@individual.net...
> stupid question ;-)
> installer file ?
> greetings
Then i dont now yet sorry ;-(
succes
news:0POdndxX3MU2UnHcRVn-1Q@rogers.com...
> > stupid question ;-)
> > installer file ?
> > greetings
do?
Are you putting them in the right directory?
Are you unzipping each file?
may seem like silly questions...but you never know
- D
"Jeremy Reaban" <jer@connectria.com> wrote in message
news:10upleqnbe5o696@corp.supernews.com...
Yep.
news:26Kdnb9e1901JnHcRVn-sw@rogers.com:
Are you using a pirated copy of the sims ?
Hell no. The first day it came out I ran out to get it. *still grumbling
over paying $68CAN*
"Rico" <BC@dt.com> wrote in message
news:Xns95E28C3F263B3ewrfdgrstnetaakeanfk@140.99.99.130...
do?
Oh come on Rico 🙁
"Bluegenie2" <me@fuil.com> wrote in news:g-OdnYyQLfMX6XDcRVn-oQ@comcast.com:
> do?
> Oh come on Rico 🙁
I'm sorry I'm just supersticious I mean suspicious.
news:Gr6dnRVFIcIh_nDcRVn-hw@rogers.com:
> over paying $68CAN*
Ok so we are narrowing down the trouble - What kind of 'game enhancing'
patches are you using ?
news:Xns95E2AA5073E42ewrfdgrstnetaakeanfk@140.99.99.130...
>> over paying $68CAN*
huh? I think I have the nude patch and that's it.
Samantha, did you see my original reply to your problem?
news:48SdnWfqwsv1GXDcRVn-oA@rogers.com...
grumbling
> >> over paying $68CAN*
"Bluegenie2" <me@fuil.com> wrote in message
news:q9KdnTEZGYIZanHcRVn-sQ@comcast.com...
I don't use PE.
> to
I looked for them they weren't there. I know to look under "ALL" But not of
them showed up.
news:f8GdnQZHoYOBSnDcRVn-tA@rogers.com...
order
> I don't use PE.
You don't need to use PE, but you do need the color enabler to see the
recolors in your game. Or some of them anyway.
You can get it here...
http://sims.ambertation.de/index.shtml
in.
need
> > to
and
of
> them showed up.
Could be that you need to install the official patch (maybe this is the
undefined 'problems with third-party-downloads) - but you won't be able to
do that with the nude patch installed. Check to see if the program you ran
to nude patch your game saved a back-up of your exe in the same directory.
MM
grumbling
> >> over paying $68CAN*
I did not even install the patch, 1st one or 2nd one. But, I do have the
color enabler.
Samantha, bear with me here, what folders do you put your sims2 downloads
in?
"Madame Mim" <mad.mim@S.P.A.M.bigpond.net.au> wrote in message
news:BDhHd.123727$K7.20918@news-server.bigpond.net.au...
> MM
> grumbling
> > >> over paying $68CAN*
enhancing'
It's the one that goes into the config folder.
news:T7WdnZxLVNEXNnDcRVn-tw@comcast.com...
> color enabler.
> in?
My Documents/EA GAMES/Sims2/Downloads
In which case my help is useless. BG2 might be on to something with the
colour enabler. Are these objects that you have downloaded things that
originally had more than one colour in the game. Many of the latest objects
(specifically those that re-colour something that only had one colour
originally) need an extra download to work. Some modders placed a link on
their pages pointing to this program and others did not. If you go to
http://www.modthesims2.com/showthread.php?t=35224 this is (I think) the
latest version of the CEP and you should try downloading and installing it.
MM
news:2ICdnXl5JoHxS3DcRVn-3A@rogers.com...
to
ran
directory.
news:48SdnWfqwsv1GXDcRVn-oA@rogers.com:
>>> over paying $68CAN*
Ah ... The nude patch ... naughty naughty.
Perhaps the nude patch is making the objects invisible ?
news:Xns95E32109C98Dewrfdgrstnetaakeanfk@140.99.99.130...
grumbling
> >>> over paying $68CAN*
You nut, lmao!
"Bluegenie2" <me@fuil.com> wrote in news:EN2dnYNdVZlmm3PcRVn-oQ@comcast.com:
> grumbling
>> >>> over paying $68CAN*
> You nut, lmao!
I'm trying to eliminate possibilities, thats all.
I'm sure the OP realizes that I'm FOS.
