[SOLVED] Problem.
Sep 7, 2019
5
Hello! So i recently bought a PC with an Intel Core I5 8400 clocked at 2.8ghz and a Nvidia GTX 1050ti. When i play tested Fortnite, the cpu and the gpu were at 100 percent,but when i play other games, i can only use the Intel UHD 630... (Tomb Raider Underworld,Tomb Raider Anniversary and Minecraft) When i searched fixes for minecraft,they all required the nvidia control panel,which i cant access because my ancient Hanns-G HW191D has only VGA support and i had to plug the monitor into the motherboard. Now,if fortnite uses the gpu,how come the other games cant?
Fortnite:
View: https://imgur.com/b6BizsV
Minecraft:
View: https://imgur.com/o0e6kmn
View: https://imgur.com/LZeBNX2
View: https://imgur.com/3JGQLN4
View: https://imgur.com/jd0A67O
If your display is connected to the motherboard output, you are NOT using your GTX 1050Ti. Would strongly recommend purchasing a new display that supports a digital interface (DVI, HDMI, DisplayPort). If that's not an option, then you will need to purchase an active adapter that converts the digital signal from your graphics card to an analog signal that your display will recognize.
-Wolf sends
Wolfshadw
-Wolf sends
5
-Wolf sends
Hi! Thanks for your reply. Yes i knew that i couldnt use the graphics card,but how the usage of it reaches 100 percent when i play fortnite?
Sep 7, 2019
5
Oh ok. Then its quite impressive for the integrated graphics to run it at 100 fps lol. Currently saving up for a monitor, the C24F390 23P Samsung that is at 90 at my local. Is it any good? (idk why the font got big)
