I am running a DV Editing system and my temps seem very high, I need to know what my options are to lower these temps without making my comp VERY loud. Heres the info
My normal Idle temps are around the 39-44 deg area and during a load they jump to around 49-55 deg My case temps can be anywhere from 30-35 deg and my Room temp is never over 23 deg ever. For one I wanna know if this would be a huge problem. Could I experience any lockups or anything from heat (I havn't yet) and if so how could I fix it. I woul like to keep the price under $300 CDN but if more is needed I would just have to do it. My business relys on a stable comp and if it crashed I could loose hours of editing.
My main causes of heat are
1) P4 2.53 (retail HS)
2) 5x HDDs (WD 1000JBs)
3) GF4 TI 4600
4) Matrox RT x.100 capture card
5) DVD Burner
My case is a Chenming Alum case with 2 80mm fans in the front 2 in the back and 2 on the PS. I have rounded cables to allow some airflow.
Now what I am planning on doing is seperating 4 of the HDDs (the ones on raid) and placing them in a second tower which I would tweak myself to work. Also I would be putting a AT Power Supply in there to take the strain off my 420w PS in my main case. Would this be a Ok idea or am I just stupid for even thinking of it.
By the way I would not be moving this comp ever, it will be sitting in the same place until I either upgrade or clean it.
Any advice you could give would be greatly appriciated.
3) GF4 TI 4600
5) DVD Burner
