Recently I added another gigabyte of dual channel PC3200 ram to my computer. This took it from 1gb to 2gb. There should have been no problem with this. However, there was a major problem. After running any of my games for a short period of time the computer totally locks up resulting in me pushing the reset button. It stops doing this after I remove the new sticks of RAM. However, I doubt it's the RAM simply because this is my second stick that have have tried in it. The computer is over clocked as you will see in the image. I tried taking the RAM down to below normal operating speed to see if maybe this stick was just sensitive, but to no avail. You can see however that these sticks (slots 3 & 4) do not have a table for 133 Mhz. I don't know if that is a huge deal or anything, but it also doesn't show the sticks' serial numbers as it does on the 2 original ones (1 & 2).
If anybody could suggest anything for me to do (yes I have tried going with all default settings), please let me know.
DFI LANParty UT RDX 200
AMD Athlon 64 3600+ (@2.75 Ghz)
2 GB PC3200 Dual Channel
