Ive been having problems with the Wireless connection on my laptop for a while now. Basically even though the signal strength is shown as excellent and hovering over the little monitor in notification area shows "Internet access" i cannot connect to the Internet via WiFi. The strange thing is when i connect an Ethernet cable the signal strength on the bottom goes up and i get Internet access but the computer seems to think its got a wireless connection, even though its actually a wired connection. Ive already tried the following
Driver Update
Windows Update
AntiVirus/Malware Scan
Firewall/Anti Virus Off
Ethernet Connection Disabled and Enabled
Changed router channel
reset wep key numerous times
Network Scan (no problems found)
System Information
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110408-1631)
Processor: Intel(R) Pentium(R) CPU P6200 @ 2.13GHz (2 CPUs), ~2.1GHz
Memory: 4096MB RAM
Available OS Memory: 3892MB RAM
Router Information
SSID : NETGEAR
Signal (dBm) : -51
Network Mode : 802.11g
Default Encryption : WEP
Default Auth : Open
Vendor : Netgear
BSSID : 00:18:4D:3A:EC:4A
Channel : 11
Frequency : 2462
Network Type : Access Point
IPCONFIG FILE
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix :
Description : DW1501 Wireless-N WLAN Half-Mini Card
Physical Address : 68-A3-C4-1D-BA-B9
DHCP Enabled : Yes
Autoconfiguration Enabled : Yes
Link-local IPv6 Address : fe80: :fc3a:2bba:200a:b9e3%14(Preferred)
PIv4 Address : 192.168.0.1
Subnet Mask : 255.255.255.0
Lease Obtained : 09 August 2011 22:45:27
Lease Expires : 10 August 2011 22:45:27
Default Gateway : 192.168.0.1
DHCP Server : 192.168.0.1
DHCPv6 IAID : 292070340
DHCPv6 Client DVID : 00-01-00-01-14-FC-56-76-F0-4D-A2-6D-F7-34
DNS Servers : 192.168.0.1
NetBIOS over Tcpip : Enabled
Ethernet adapter Local Area Connection 2:
Media State : Media Disconected
Description : Broadcom Virtual Wireless Adapter
DHCP Enabled : Yes
Ethernet adapter Local Area Connection:
Description : Atheros AR8152 PCI-E Fast Ethernet Controller
Physical Address : F0-4D-A2-6D-F7-34
DHCP Enabled : Yes
Tunnel adapter isapter.{CA0B0512-AAD3-4C00-BF90-674DB4237239}:
Description : Microsoft ISATAP Adapter
Physical Address : 00-00-00-00-00-00-00-E0
DHCP Enabled : No
Tunnel adapter Local Area Connection* 9:
Description : Microsoft 6to4 Adapter
DHCP Enabled : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description : Teredo Tunneling Pseudo-Interface
DHCP Enabled : No
IPv6 Address : 2001:0:5ef5:79fb:14e5:32d2:3f57:fffa (Preferred)
Link-local IPv6 Address : fe80: :14e5:32d2:3f57:fffa%13(Preferred)
Default Gateway : : :
NetBIOS over Tcpip : Disabled
Tunnel adapter isatap.{B3E5EFFB-39C5-4E18-BBEC-3BC2BEB458E3}
Description : Microsoft ISATAP Adapter #4
DHCP Enabled : No
Driver Update
Windows Update
System Information
Memory: 4096MB RAM
Router Information
SSID : NETGEAR
Signal (dBm) : -51
Default Auth : Open
Vendor : Netgear
Channel : 11
Frequency : 2462
IPCONFIG FILE
DHCP Enabled : Yes
DHCP Enabled : Yes
DHCP Enabled : Yes
DHCP Enabled : No
DHCP Enabled : No
DHCP Enabled : No
DHCP Enabled : No
