Problems installing 64-bit windows 7. Help!
the_doghead
17
Hi there, I had a little flick through the forums and found a couple of similar threads, but none describing exactly what I'm experiencing. So here goes.
Put together a PC, tried to install 64-bit windows 7, but when I look at system settings, it says 32-bit operating system. Here is my set up:
MSI P67A-G45 (B3) *This was bought 2nd hand from ebay, and didn't come with drivers disc.*
Core i5 2500k
8GB G.Skill Ripjaws X 1333 MHz
GTX 560Ti
500gb HDD
So, I know that there are some compatibility problems with the board and certain types of G.Skill RAM, but looking in the system settings in Windows, it recognises there are 8GB installed, but only 3 available of course due to 32-bit windows.
This is my first build. Starting to get a bit frustrated as I just expected to install 64-bit windows straight up. Any help would be greatly appreciated.
The only thing I can really think of is that the motherboard is somehow remembering settings from its previous use? Is that even possible?
Thanks in advance guys (and gals).
the_doghead
17
The hard drive was brand new, no operating system previously on it.
The current bios is... v1.8 I think, that's just off the top of my head. I'm just trying something with Windows and I will give you a definitive answer after that.
Thanks for your help.
the_doghead
17
I'm just trying to 'upgrade' now, hoping that will magically transform it somehow from 32-bit to 64-bit. Before this, it showed 32-bit windows, 8gb ram (3gb available).
The 'upgrade' is almost finished, I'll let you know how that goes, then check the bios and system properties for you.
the_doghead
17
These are the Speccy results:
OS: MS Windows 7 Home Premium 32-bit
CPU: Intel Core i5 2500k @ 3.30GHz
Sandybridge 32nm Technology
RAM: 8.00 GB Dual-Channel DDR3 @ 665 MHz (9-9-9-24)
MOBO: MSI P67A-G45 (MS-76730) (SOCKET 0)
GPU: L90D+ DVI (1280x1024@60Hz)
1024MB GeForce GTX 560 Ti (ASUStek Computer Inc)
HD: 488GB Western Digital WDC WD5000AAKS-60WWPA0 ATA Device (SATA)
Optical Drive: ATAPI iHAS124 B ATA Device
Audio: HD Audio Device
the_doghead
17
That was actually my first thought, that for some reason 32-bit windows was on the 64-bit disc. But does that even happen?!
As for drivers, as I said the MOBO didn't come with a driver disc so I'm having to do it all manually.
