Problems installing driver for GTX 970 on W7pro for Premiere
ulk
5
I bought a new Geforce GTX 970 G1 graphic card. for my Premiere Pro CS5. System is Windows 7 Pro 64 bit.
After installing the latest driver (353.06), I do not have any CUDA functionality in Premiere Pro. GPUsniffer.exe says following:
Microsoft windows [version 6.1.7601]
Device: 00000000002C4858 has video RAM 4095 MB
Vendor string: NVIDIA Corp.
Renderer string:: GeForce GRTX 970/PCIe/SSE2
Version string: 2.1.2 NVIDIA 353.06
OpenGL version as determined by Extensionator...
OpenGL version: 2.0
Supports shaders!
Supports BGRA -> BGRA Shader
Supports VUYA Shader -> BGRA Shader
Supports YUV 4:2:0 -> BGRA Shader
Testing for CUDA support...
Didn't find any devices that support CUDA.
Completed Shader test!
Internal return value: 7
I think OpenGL Vers. 2.0 is suspicious !
Performance of Card is much too slow - I think.
Can anyone help me with this problem??
Greetings from Berlin!
Uli
Thanks Sora, for your question and response !
It is the PC, where I do Video- and Photo-Editing.
Do not play games on it.
One suspicion: Is it possible, that the problem has anything to do with windows itself?
For some time the updating of some windows-updates fail and I can not update manually.
Hope this is not the reason - otherwise I have to install everything again.....horror!
Two screenshots here:
http://www.vistafilm.de/download/
"Fehlgeschlagen" => failed !
"Erfolgreich" => OK !
Haven't found HDMI-Device in Device-Manager.
Any other Idea? Look at my answer to "sora".
Thanks for your readiness to help!
