Every time I try to install Skype I get the blue screen of death!
I have a HP ProBook 450-G3 laptop, windows 7 sp1
I just did a clean reinstall and it's all updated (including IE11)
I tried most suggestions found online and talked to MS CS. So far no solution has been found
The story is the same: I try to install, it does NOT, then it cycles in a boot/re-boot state until I stop it and start on safe mode with networking. Then I need to recover the computer going back to the previous restore point.
Skype does not appear among installed programs, but sometimes there was a folder under program Files (x86). Skype folder is present in the %appdata%roaming and when searching the registry after some interrupted installations there is a voice or two, but sometimes there could be over 50.
Any cue? Thank you,
-fabrizio
Any cue? Thank you,
-fabrizio
