Problems of Sapphire HD 7870 dual monitor
Billy John Mostajo
I have a Sapphire AMD Radeon HD 7870
I bought similar monitor to the one I use but the second one wont detect.
I connect the first monitor with VGA adapter to DVI, and the second is VGA converter to HDMI.
Please help!!!!
it works here with a converter..
I have an
ASUS HD 7870 DCCII V2 GDDR5 2GB
maybe you should try another converter..
maybe the one that came with the card If you got one with the card when you bought it..
or try what slayzombi said..
