Hi,
I'm trying to overclock my board with the following configuration:
Core2Duo 1.8ghz E4300
Corsair TWIN2X2048-6400, PC26400, 2GB Kit, 5-5-5-18, 240pin DIMM
XFX nVidia GeForce 7900GT 470Mhz
I can't set the CPU Host Control to "enabled" so that it stays in that mode. Even if I increase the fsb frequence by as little as a 8mhz, or even not at all, my computer boots twice and the cpu host control mode is back to "disabled". I have tried many different combinations of settings, all CPU related stuff is disabled, CIA2 disabled.
Any ideas what could be wrong? When the computer restarts the first time it halts at the point where it says "memory check"...I can only see the first two letters of those words (i.e. "Me").
Thanks a lot for any advice you can give me, I'm a newbie... but I think this is a hardware-related compatibility problem, not my fault !
