problems pc keeps crashing when playing games.
Feb 15, 2018
4
hi guys when I boot up my machine it appears to run fine. I load a game and after about 10 minutes instead of the fans kicking in to cool my machine my display goes off and totally crashes the machine, its only been happening for the past few days and i cant seem to figure out what the problem is what does anyone advise? please help
I've ran a reliability search and these are the errors I've found.
https://postimg.org/image/5i7m5fmd9/
https://postimg.org/image/bj5b2ntlp/
Windows key ->sysdm.cpl -> enter -> Advanced Tab -> Startup and Recovery Settings
- Check "write an event to the system log"
- Uncheck "Automatically restart"
- Write debugging information, set to small memory dump 256k. Ensure Small Dump Directory is %SystemRoot%\Minidump.
- Hit OK
This crash was caused by a malfunctioning ATI display driver.
I would start by using display driver uninstalled to remove all your display drivers in safe mode. After that, download and install your latest graphics card drivers in normal Windows mode.
I would also update your motherboard chipset drivers as well. They can be found on your motherboard manufacturer's web page for your motherboard. Updating your motherboard BIOS can also help with graphics issues.
You used DDU in safe mode right?
- Try running the PC using integrated graphics if you have them.
- Upload a crash dump file from C/Windows/Minidump so we can see for sure if it's the graphics card driver.
that folder is empty when i log in how do i create a mini dump?
- Hit OK
