Problems setting Gamma on my PC
dynixi
4
I'm having issues adjusting Gamma on my PC. What happens is, I would drag the bar on the gamma settings to max, and it would show the gamma settings that I set it as, but revert immediately back to the original gamma.
I've tried this in both Nvidia Control Panel and Windows Calibration, both do the same thing.
Here are my specs if that helps diagnose my problem:
Asus Formula VII Motherboard
Intel i7 4790K
Nvidia Asus Strix GTX 970
Samsung 250GB SSD
Cooler Master 650W PSU
G.SKILL Trident X 16GB
Monitor(s): Asus VG248QE & Asus VE248H
Thank you very much.
Woah. A few days ago, I was having this issue on my ROG Swift!
After hours of messing around, I finally realized the issue. It was f.lux!
Try disabling F.lux, then try...
Try disabling F.lux, then try again. Good luck!
Oh my god thanks so much!!! I never would've thought that was the problem.
Latest posts
