Problems Starting Up Cold
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Recently, I have been having problems with starting up my PC after is
has been turned off for me the 1 hour. No error message though it has
said unable to boot A: sometimes. I have ran WD DATA Lifeguard on the
drives nothing shows. I have tried multiple drives same things. Have
wrote full O's to the drive reinstalled just OS and same thing occurs.
Sometime I get it started after about two or three attempts.
Any ideas or suggestions?
Thanks,
Ron
Replace the C2032 3v lithium battery. These batteries are inexpensive. When
they wear out, all sorts of odd things may happen. Let us know if that works.
.... Ben Myers
>Thanks,
>Ron
> ... Ben Myers
>>Thanks,
>>Ron
Ben,
Thanks for the quick response. Is this going to mean that I am to have
to reset things in my BIOS or not?
Ron
Probably. The system should start up and tell you that the CMOS settings are
corrupted or something similar. But using the BIOS defaults (F5 key as I
recall) should work. If you have a parallel port printer, the non-default ECP
settings usually work best... Ben Myers
>> ... Ben Myers
>>>Thanks,
>>>Ron
>Ben,
>Ron
