Archived from groups: microsoft.public.windowsxp.perform_maintain (
More info?)
Look here:
http://www.kellys-korner-xp.com/xp_s.htm
Scroll down to:
Search - Doesn't Work
Look here:
http://www.kellys-korner-xp.com/top10faqs.htm
Click on: Why doesn't Help and Support work?
Courtesy of Kelly
Microsoft-MVP Windows® XP-Shell/User
2004 Windows MVP "Winny" Award
Add or Remove - White Space
http://www.kellys-korner-xp.com/xp_a.htm#ws
[[This is generally due to the DisplayIcon having a negative number. From
here you can either remove the negative number or remove the last
application listed:
Start/Run/Regedit:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{} ]]
AutoCad Fix
http://www.kellys-korner-xp.com/regs_edits/autocadaddremovefix.zip
Autodesk Land Desktop 3 Fix
http://www.kellys-korner-xp.com/regs_edits/autodesk-landdesktop3-addremovefix.zip
I have AutoCAD LT 2000i. The white space in Add or Remove Programs usually
shows up after the AutoCAD LT 2000i listing. If you want to tweak the
registry...
{5783F2D7-0065-0409-0000-0060B0CE6BBA}
Value Name: DisplayIcon
Value Type: REG_SZ
Value Data: C:\Program Files\AutoCAD LT 2000i\aclt.exe,-1
Notice the aclt.exe,-1?? You can change it to read aclt.exe,1
Or you can run one of the fixes. I have both autocadaddremovefix.zip &
autodesk-landdesktop3-addremovefix.zip. They both include icons.
autocadaddremovefix.vbs is the one that works for me. It's easier to use
the fix than changing the -1.
I get the white space in Add or Remove Programs every time that I add or
remove a program. It isn't always AutoCAD LT that has the white space after
it, sometimes it's another program. At any rate, one of the fixes will
work. Until the next time. ;-)
autocadaddremovefix.vbs adds an autocad.ico icon to the %systemroot%\web
folder. It also adds this to the registry >>
{5783F2D7-0101-0409-0000-0060B0CE6BBA}
Value Type: REG_EXPAND_SZ
Value Data: %systemroot%\web\autocad.ico
autodesk-landdesktop3-addremovefix.vbs adds an acad.ico icon to the
%systemroot%\web folder. It also adds this to the registry >>
{5783F2D7-0138-0409-0000-0060B0CE6BBA}
Value Data: %systemroot%\web\acad.ico
From snowman...
AutoCAD 2002 is
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:2DC31387-B001-4ED2-9688-90ABE96952F2@microsoft.com,
Bernie <Bernie@discussions.microsoft.com> hunted and pecked:
> After upgrading from Win98 to XP Home Edition and later installing SP2
> several features are not working:
> Search panel is 'blank' and cannot conduct any search for files
> The Help & Support feature won't start
> Add/Delete Programs has a large blank space in the middle of the list
> of programs.
> After getting used to Win98, here are a few heacaches to worry about.
> Any ideas (besides buying a new computer?).
