I am very new to overclocking and not sure if I have played with the correct numbers in BIOS
The issue is that when I try to run my memory at 2000Mhz I end up with BSD.
Could it be that my motherboard does not support 2000Mhz? or Did I just do it wrong?
I managed to get 1840Mhz, which is not bad at all, but just wondering why I can't have 2k.
Also If someone could give me some indication if my CPU settings are ok?
Looks like that processor is running smoothly at the current clock, but I would like to aim higher if possible.
Asus M4A89TD PRO
AMD Phenom II X6 1090T Black Edit (at 4,15Ghz ~50celsius)
Noctua NH-D14
2x2GB Adata Gaming Series DDR3 2000Mhz 9-9-9-24 1,55 - 1,75v
2x4GB CORSAIR high performance XMS3 2000Mhz 9-10-9-27 1.65v
(NVIDIA GeForce GTX660 OC 2048 MB)
This is what I changed in BIOS:
CPU ratio - 18
AMD Turbo - Disabled
CPU Bus - 230
DRAM - 1840Mhz
CPU Voltage offset + 0.1875 >> 1.6995
DRAM Voltate - 1.65
Everything else in bios is on AUTO and you can see more from the pictures.
http://
Asus M4A89TD PRO
Noctua NH-D14
CPU ratio - 18
CPU Bus - 230
DRAM - 1840Mhz
DRAM Voltate - 1.65
http://
