Problems with ASUS p6t-se booting (HELP)
Samasam
13
To start, i try to avoid posting threads, as i'm aware it can be the cancer of some forums, however i'm almost a month in on this small project and iv'e currently had no success.I hoped someone with some experience with this board or X58 builds might be able to give me some advice and point me in the right direction
I got hold of an asus P6T-SE motherboard from a friend and it hasn't been in a system for a long while. the motherboard was sat in an old Coolermaster HAF 932 case and from what he said it's disassembled for a few years. I took the motherboard out, gave it a quick visual check and everything seemed fine with the board (nothing looks fried or broken), so it got me thinking on doing a X58 build. Heres where the problems started;
I bought an i7 930 from ebay, put everything together with some spare ram i had lying around, and did a test boot. At first i'm getting nothing. No beeps, only the power LED on the motherboard. i began trying to troubleshoot it and removed the ram i had installed. i then got a few beeps (1 long and 2 short beeps) i've looked this up on other forums and the only thing i can find is a video card error. i'm confused as to why i'm getting this code, but instead i began trying to troubleshoot more. I replaced the PSU for a new one, and also got hold of some low density DDR3 (Corsair XMS3 Tri channel 6x2gb). i tried each module of RAM individually to ensure that they're not faulty/faulty RAM slots. i tried different GPU's (GTX 670 and GTX 960) and finally i came to the conclusion that it could only be the motherboard or the CPU. I decided replace the CPU as my final attempt to get this board working. I ordered a Xeon x5660, installed it and i thought i cracked it. finally the board comes to life, fans spin, but to spoil it all, i get no video output. in this time i also tried some of the basic stuff such as removing CMOS battery, bread boarding the system so theres no possibility of shortages within a case, etc.
a few things to add to anyone that might have any ideas is that the board acts strange when it comes to powering it on. it i press the power switch, the fans will spin for about half a second then shut off. however if i hold the switch, the fans spool up and runs continuously. i'm now at a point where i'm not sure what else it could be. i'm 99% sure it's not a compatibility issues, and i have no idea where to start when it comes to BIOS compatibility. if anyone has any ideas, even a small one, let me know. it'd be a shame to see this board go to waste since there's so few.
As stated I tried different GPUs (GTX 670 and GTX 960). The motherboard doesn’t have any video ports so it’d be impossible to get any video output without s graphics card. In other words, I used a GPU
Thanks for the feedback though
Sorry...I somehow missed that. I have a P6T Deluxe that I've used a lot and I'd like to see you get it going. What BIOS are you using?
I am almost sure there are earlier ones that don't support the later processors because I upgraded mine from an i7-920 to an i7-980 and according to ASUS....I HAD TO UPGRADE THE BIOS.
Thanks for your response, this is the kind of stuff i needed to hear. I've not yet had experience with flashing a bios on a motherboard that i can't get to post. Is it as simple as getting the correct files and making a bootable USB file? or am i completely wrong.
Again though, i feel like im getting somewhere with this board now.
That CPU is not supported by the ASUS P6T Deluxe. https://www.asus.com/us/Motherboards/P6T_Deluxe/HelpDesk_CPU/
@jay32267
1. your wrong in telling it is not supported,
2. your web page link is to the P6T Deluxe , and the OP has the ASUS P6T SE
as per the web page for the P6T SE : https://www.asus.com/Motherboards/P6T_SE/HelpDesk_CPU/
it is supported
@Samasam
have you confirmation the CPU is actually functional and or the motherboard was functional?
your seemingly working with assumption the cpu sold is functional, and assuming the motherboard is.
you could be seeking answer for a long timer at this rate.
you need to eliminate the "is this functional?", and make it a "confirmed working order"
hard to do I understand with such old hardware.
but hard to verify unless you have another 1366 motherboard that supports that cpu known working motherboard, and test the cpu eliminating the issue and pointing your problem to the x58 motherboard (p6t-se)
Also you state " I ordered a Xeon x5660" that cpu isn't supported on the P6T-SE so don't expect miracles.
ref: https://www.asus.com/Motherboards/P6T_SE/HelpDesk_CPU/
question of video card, I suspect that board will not support any video card needing UEFI BIOS, but the old Classical BIOS, thus testing video card should be limited to prior to GTX 750TI for now.
finally the ram issue, what is the exact make and model of ram stick you are trying to use ?
Thanks for your responses.
To start, buying the Xeon was a mistake on my part, I jumped the gun without doing any research at all. Following that it’s been returned and I’m looking at getting hold of a cheap i7 920, which should be compatible with the BIOS
I can’t access the BIOS currently so surely it’s impossible to flash without a CPU that’s compatible? Unless there was another way that I didn’t know about, this is why I assumed I had to buy a i7 920
The RAM that I am using is Corsair XMS3 DDR3 6x2gb (TR3X6G1600C9)
In reply to The Paladin, I’ve tried all of the different RAM configurations so I’m pretty sure it’s not a RAM compatibility problem unfortunately
All of the parts that I order through eBay are tested before dispatch - I know that doesn’t 100% confirm they are working, but gives me confidence that they’re functional.
I am fairly certain you need a working CPU to upgrade the BIOS. I think there might be some cases where you don't, but I think "generally" you do.
As far as the i7-920...yeah it's old...but it's not that much of a slouch. I used it to play all the most recent games at 1080p and it never hit 50% and that was only about 6 months ago.
That’s what I’ve read online too, I’ve seen some i7 920’s for less than £20, so I think I’m going to try get hold of one of them. I think the i7 920/940 is the most ‘compatible’ chip for this board since I believe they don’t require a BIOS update to run. They should run off the earliest BIOS that came with the board (if my research is correct). Hopefully this should be the solution to the problems.
As far as the i7 920 goes, I agree with you. I feel it’s still a very capable chip, especially with a decent overclock.
I’ll try get this CPU ordered and hopefully I can come up with a solution on this thread.
I agree with you. I'm pretty sure the i7-920 was one of the first processors for that board. Mine came on an Alienware machine from 2008-2009.
I played all the games that I played without overclocking.
Then I came across an i7-980x for a good price but I got a bad processor.
Then I came across an i7-980 for a good price and that's what's in there now.
The 980 is almost twice as fast as a 920....BUT it cost me around $200.
Although I am positive I had to upgrade the BIOS for the 980...and I am now positive I used EZFlash with a USB stick.
Great news! The system is up and running. turns out it was a BIOS compatibility issue. I got hold of an i7 920 and the board booted straight up. The BIOS did happen to be quite early, which meant only the i7 920/940 would work with it due to them being the first i7's available at the time.
Thanks to Jay32267 and The Paladin for noticing the BIOS issue. Was considering throwing it in the trash if this didn't fix it. Another ASUS P6T lives on.
Ha...I am happy for you. Especially since I am a P6T fan. I am still running my P6T as my bedroom gaming machine on a 55" with an i7-980.
You may want to keep the 980 or the 990 in mind if you can get one for a good price. Both of them will basically almost double the processing speed of a 920 (which is what I had originally). Although the 920 should run any game that's out there now. Just remember, if you do that you may need to update the BIOS.
Cheers.
