Question Problems with Aura Sync
May 14, 2019
I’m using a Corsair Carbide Spec-Delta RGB Case that comes with fans that are compatible with Aura sync. I plugged in the 12v connector to the RGB header on the board and on power on the fans are red led. I want them to be green, as that’s the theme of the rest of my leds in my setup.
I’ve installed the Aura Sync, but it keeps telling me that AuraService is currently unavailable and when I downloaded the aura sync that is specific to my motherboard (asus b450m prime) it says that I need to connect compatible devices, but the fans are already connected to the RGB header.
If there is a way to simply turn the fans green that’s all I necessarily need, otherwise I need help figuring out how to get AuraSync to recognize the fans of the Corsair Carbide SpecDelta rgb.
I’ve tried downgrading software, unblocking the zip folder with the install, and a complete factory reset.
