G
Guest
Guest
Hi, i have just recieved all the bits for my newd pc that i'm building myself. i have installed everything, plugged it in and pressed the power button. all the fans, lights work etc, but my screen doesn't recieve a signal. its all plugged in correctly and the cable definatley works as i'm using it right now. heres what ive got....
MB - Geforce6100PM-M2, micro ATX, 64-bit, AM2+
Processer - Athlon 64 X2 Dual Core 4200+, AM2 with heatsink and fan
Graphics Card - 1GB Geforce 8400 256mb
RAM - 2x 2gb PC2-4300 533mhz DDR2
HDD - 250gb Western Digital SATA
Case - Galaxy ATX Tower with 450w PSU
the screen is connected to the graphics card via VGA
all the bits work as far as i know, only processer and HDD are second hand but should work.
any help and ideas appreciated
