Hi, so recently Ive been getting BSOD daily, and they vary a little (like "critical process died" or "system exception something") but it doesnt exactly tell me which driver is at fault (except one time one it said something about volmx or something which I think was the audio driver), I really dont know whats causing it, Ive had problems like these in the past, 1 year ago, when I replaced my HDD and everything was fine, but this isnt a dying hdd, Ive done some scans and theres nothing wrong with it.
So this is what I got from BlueScreenView: 080219-23343-01.dmp 8/2/2019 10:37:42 AM SYSTEM_SERVICE_EXCEPTION 0x0000003b 00000000
This is what I got from WhoCrashed:
System Information (local)
Computer name: DESKTOP-D5T0UA1
Windows version: Windows 10 , 10.0, version 1903, build: 18362
Windows dir: C:\Windows
Hardware: ASUSTeK COMPUTER INC., M5A99FX PRO R2.0
CPU: AuthenticAMD AMD FX(tm)-8350 Eight-Core Processor AMD8664, level: 21
8 logical processors, active mask: 255
RAM: 17074483200 bytes (15.9GB)
Crash Dump Analysis
Crash dumps are enabled on your computer.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Fri 8/2/2019 10:37:42 AM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\080219-23343-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1BC900)
Bugcheck code: 0x3B (0xC0000006, 0xFFFFF80761490582, 0xFFFF828F39A3D840, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!setjmpex+0x8229)
And Im currently going to run Verifier to see if it finds something, Can someone help or give me some advice? Thanks!
c0000006 fffff807
61490582 ffff828f39a3d840 00000000
00000000 ntoskrnl.exe ntoskrnl.exe+1bc900 x64 ntoskrnl.exe+1bc900 C:\Windows\Minidump\080219-23343-01.dmp 8 15 18362 1,773,364 8/2/2019 10:39:31 AM This is what I got from WhoCrashed:
Crash Dump Analysis
C:\Windows
C:\Windows\Minidump
