Problems With CD Drive...
G
Guest
Guest
Archived from groups: microsoft.public.windowsme.general (More info?)
my cd drive has stopped working! it shows up in windows explorer and device
manager. however, in device manager, it says udnerneath 'this device is not
working properly'. i can't load any cds in windows from the cd drive, and my
cd burning software does not recognise it, so i can't burn cds. what should i
do?
Heather
475
Take it to a shop. I had that happen with my CD Burner.....none of the
burner software or Windows Explorer would recognize that there was a blank
CD in the drive. Turned out that the connection (IDE ribbon?) was no good
and Willy replaced it. Works fine now. In fact, he burned a music CD just
to make sure before I left with it.
Cheers....Heather
"jclmusic" <jclmusic@discussions.microsoft.com> wrote in message
news:CF8AB0B1-5D8A-41F4-B029-7FEBA67E757C@microsoft.com...
device
not
my
should i
> do?
G
Guest
Guest
update on the situation: i just tried some other cds. some of them work n i
managed 2 install of 1. however many different cd writing programs i try,
none of them work tho! :(
> Cheers....Heather
> device
> not
> my
> should i
> > do?
G
Guest
Guest
i've also noticed, it now says in device manage 'this device IS working
properly', when it's obviously not! still can't burn cds!
> > Cheers....Heather
> > device
> > not
> > my
> > should i
> > > do?
Heather
475
PS......in Device Manager, it said the same as yours does.
HF
device
not
my
should i
> do?
G
Guest
Guest
Try a Lens Cleaning CD (obtainable from most audio CD stores) - with a bit
of luck, may only be a dirty lens/laser. - But your potted history suggests
there may be worse. You may then have to determine whether it's a hardware
(CD-ROM) or WinMe issue.
Mart
news:0D91DD6B-DAF5-4E07-80F2-8690E8B0E5F9@microsoft.com...
>> i
>> > blank
>> > good
>> > just
>> > Cheers....Heather
>> > device
>> > > is
>> > not
>> > > and
>> > my
>> > should i
>> > > do?
G
Guest
Guest
it happened after i accidently installed linux. then it's been like this
since i got windows back. so i assumed it was ME?
> Mart
> >> i
> >> > blank
> >> > good
> >> > just
> >> > Cheers....Heather
> >> > device
> >> > > is
> >> > not
> >> > > and
> >> > my
> >> > should i
> >> > > do?
G
Guest
Guest
jclmusic:
Your question: what should I do?
My answer: get a new CD-Rom drive, unless you want to reinstall your old
one.
Harry.
device
not
my
should i
> do?
Heather
475
Harry.....why would he want to reinstall his *old one*......it isn't
working. He should take his computer to a reputable tech and get it checked
out.
Heather
"webster72n" <hbethke@copper.net> wrote in message
news:uES5PB6nFHA.3288@TK2MSFTNGP09.phx.gbl...
> jclmusic:
> one.
> Harry.
> device
> not
and
> my
> should i
> > do?
G
Guest
Guest
You install Linux, and get problems - and the problem is from ME?>?????
THINK!!
Noel Paton (MS-MVP 2002-2005, Windows)
Nil Carborundum Illegitemi
http://www.btinternet.com/~winnoel/millsrpch.htm
http://tinyurl.com/6oztj
Please read http://dts-l.org/goodpost.htm on how to post messages to NG's
news:FCFF608E-68F2-4561-8C30-153A788CE4D6@microsoft.com...
>> bit
>> suggests
>> hardware
>> Mart
>> >> work n
>> >> i
>> >> try,
>> >> > the
>> >> > blank
>> >> > no
>> >> > good
>> >> > CD
>> >> > just
>> >> > Cheers....Heather
>> >> > > and
>> >> > device
>> >> > > device
>> >> > > is
>> >> > not
>> >> > > drive,
>> >> > > and
>> >> > my
>> >> > > what
>> >> > should i
>> >> > > do?
G
Guest
Guest
lol, u don't get what i meant. i mean linux must have messed up windows. so
how can i fix that? i would just scrub everythin n start again, but i need
the cd writer 2 back up my stuff before i do that!
> THINK!!
> >> bit
> >> suggests
> >> hardware
> >> Mart
> >> >> work n
> >> >> i
> >> >> try,
> >> >> > the
> >> >> > blank
> >> >> > no
> >> >> > good
> >> >> > CD
> >> >> > just
> >> >> > Cheers....Heather
> >> >> > > and
> >> >> > device
> >> >> > > device
> >> >> > > is
> >> >> > not
> >> >> > > drive,
> >> >> > > and
> >> >> > my
> >> >> > > what
> >> >> > should i
> >> >> > > do?
Heather
475
LOL!! It is extremely simple. Take it to a computer tech and get the
durned CD drive fixed, back up your stuff and then clean up your computer.
Or did I miss something here......grin.
Heather
news:E812DF3A-79A4-493B-961F-094440BE4690@microsoft.com...
so
> > THINK!!
NG's
this
a
> > >> bit
> > >> suggests
> > >> hardware
> > >> Mart
working
> > >> >> work n
> > >> >> i
i
> > >> >> try,
of
> > >> >> > the
was a
> > >> >> > blank
was
> > >> >> > no
> > >> >> > good
music
> > >> >> > CD
> > >> >> > just
> > >> >> > Cheers....Heather
explorer
> > >> >> > > and
> > >> >> > device
> > >> >> > > device
> > >> >> > > is
> > >> >> > not
> > >> >> > > drive,
> > >> >> > > and
> > >> >> > my
cds.
> > >> >> > > what
> > >> >> > should i
> > >> >> > > do?
G
Guest
Guest
jclmusic:
You didn't say whether you tried to replace the cable!
And as a next step, cleaned the drive?
How about it???
Harry.
so
> > THINK!!
NG's
this
a
> > >> bit
> > >> suggests
> > >> hardware
> > >> Mart
working
> > >> >> work n
> > >> >> i
i
> > >> >> try,
of
> > >> >> > the
was a
> > >> >> > blank
was
> > >> >> > no
> > >> >> > good
music
> > >> >> > CD
> > >> >> > just
> > >> >> > Cheers....Heather
explorer
> > >> >> > > and
> > >> >> > device
> > >> >> > > device
> > >> >> > > is
> > >> >> > not
> > >> >> > > drive,
> > >> >> > > and
> > >> >> > my
cds.
> > >> >> > > what
> > >> >> > should i
> > >> >> > > do?
G
Guest
Guest
there's a way 2 fix it without losing all ur stuff?
> Heather
> so
> > > THINK!!
> NG's
> this
> a
> > > >> bit
> > > >> suggests
> > > >> hardware
> > > >> Mart
> working
> > > >> >> work n
> > > >> >> i
> i
> > > >> >> try,
> of
> > > >> >> > the
> was a
> > > >> >> > blank
> was
> > > >> >> > no
> > > >> >> > good
> music
> > > >> >> > CD
> > > >> >> > just
> > > >> >> > Cheers....Heather
> explorer
> > > >> >> > > and
> > > >> >> > device
> > > >> >> > > device
> > > >> >> > > is
> > > >> >> > not
> > > >> >> > > drive,
> > > >> >> > > and
> > > >> >> > my
> cds.
> > > >> >> > > what
> > > >> >> > should i
> > > >> >> > > do?
Heather
475
Yes......I told you that yesterday!! You say that your CD burner will not
work. I told you I had the same problem. A computer tech replaced a part
that was not working. Didn't cost much.
IOW.....stop messing around and take it to a competent tech.....no one here
can fix your CD drive if it is a hardware problem.
Heather (must remember to do a backup)
news:B535DE34-6733-4112-886E-C73B322D38CA@microsoft.com...
computer.
> > Heather
windows.
> > so
need
ME?>?????
> > > > THINK!!
> > NG's
like
> > this
with
> > a
> > > > >> bit
history
> > > > >> suggests
> > > > >> hardware
> > > > >> Mart
> > working
them
> > > > >> >> work n
> > > > >> >> i
programs
> > i
> > > > >> >> try,
Burner.....none
> > of
> > > > >> >> > the
there
> > was a
> > > > >> >> > blank
ribbon?)
> > was
> > > > >> >> > no
> > > > >> >> > good
a
> > music
> > > > >> >> > CD
> > > > >> >> > just
> > > > >> >> > Cheers....Heather
message
> > explorer
> > > > >> >> > > and
> > > > >> >> > device
'this
> > > > >> >> > > device
> > > > >> >> > > is
> > > > >> >> > not
the cd
> > > > >> >> > > drive,
> > > > >> >> > > and
> > > > >> >> > my
> > cds.
> > > > >> >> > > what
> > > > >> >> > should i
> > > > >> >> > > do?
G
Guest
Guest
no, no, no, lol. how can it be a hardware problem if it's cos linux messed it
up? there must be a way 2 put rite what it's done.
> computer.
> > > Heather
> windows.
> > > so
> need
> ME?>?????
> > > > > THINK!!
> > > NG's
> like
> > > this
> with
> > > a
> > > > > >> bit
> history
> > > > > >> suggests
> > > > > >> hardware
> > > > > >> Mart
> > > working
> them
> > > > > >> >> work n
> > > > > >> >> i
> programs
> > > i
> > > > > >> >> try,
> Burner.....none
> > > of
> > > > > >> >> > the
> there
> > > was a
> > > > > >> >> > blank
> ribbon?)
> > > was
> > > > > >> >> > no
> > > > > >> >> > good
> a
> > > music
> > > > > >> >> > CD
> > > > > >> >> > just
> > > > > >> >> > Cheers....Heather
> message
> > > explorer
> > > > > >> >> > > and
> > > > > >> >> > device
> 'this
> > > > > >> >> > > device
> > > > > >> >> > > is
> > > > > >> >> > not
> the cd
> > > > > >> >> > > drive,
> > > > > >> >> > > and
> > > > > >> >> > my
> > > cds.
> > > > > >> >> > > what
> > > > > >> >> > should i
> > > > > >> >> > > do?
Heather
475
I GIVE UP!!
HF.
news:73EC658B-34B4-4B7C-AA21-1BBACC6B0848@microsoft.com...
it
not
part
here
the
> > computer.
> > > > Heather
> > windows.
> > > > so
but i
> > need
> > ME?>?????
> > > > > > THINK!!
messages to
> > > > NG's
> > like
> > > > this
stores) -
> > with
> > > > a
> > > > > > >> bit
> > history
> > > > > > >> suggests
it's a
> > > > > > >> hardware
> > > > > > >> Mart
message
device IS
> > > > working
of
> > them
> > > > > > >> >> work n
> > > > > > >> >> i
> > programs
> > > > i
> > > > > > >> >> try,
> > Burner.....none
> > > > of
> > > > > > >> >> > the
> > there
> > > > was a
> > > > > > >> >> > blank
> > ribbon?)
> > > > was
> > > > > > >> >> > no
> > > > > > >> >> > good
burned
> > a
> > > > music
> > > > > > >> >> > CD
> > > > > > >> >> > just
> > > > > > >> >> > Cheers....Heather
> > message
windows
> > > > explorer
> > > > > > >> >> > > and
> > > > > > >> >> > device
udnerneath
> > 'this
> > > > > > >> >> > > device
> > > > > > >> >> > > is
> > > > > > >> >> > not
from
> > the cd
> > > > > > >> >> > > drive,
> > > > > > >> >> > > and
> > > > > > >> >> > my
burn
> > > > cds.
> > > > > > >> >> > > what
> > > > > > >> >> > should i
> > > > > > >> >> > > do?
G
Guest
Guest
Heather:
According to his very own description, Lenux screwed it up for him and in my
book trying tops studying.
He just might be pulling all of our legs and have an answer to his question
already in his back pocket, unless I'm 'way off'.
Why bash our heads in over this?
Let's wait and see.
Harry.
"Heather" <figgs@invalid.invalid> wrote in message
news:eNydcJ6nFHA.3564@tk2msftngp13.phx.gbl...
checked
> out.
> Heather
> > jclmusic:
> > one.
> > Harry.
> > device
is
> > not
> and
> > my
> > should i
> > > do?
G
Guest
Guest
jclmusic wrote ...
> it
<snipped>
OK, so let's pursue that theory a little - but first you need to prove that
your PC will recognise AND read (all) your CD's.
My standard (edited) response to check-out CD-ROM's in Real Mode DOS -
please use the 'bits' applicable to your CD-RW :-
Consider the following, which "ass-u-me-s" two CD-ROM drives are fitted (CD
reader and CD reader/writer) in the computer - but if only one device, amend
accordingly :-
To 'see' them in Real Mode DOS, Boot, using your WinMe Startup (floppy) Disk
in the A: drive.
Select option 2. Start computer with CD-ROM support.
Let the screen information scroll until you eventually see a line which
should report a drive letter for each of the CD-ROM's - but note that they
may not necessarily the same letter as you would expect to see in Windows.
For example, you should see TWO CD-ROMS, becoming the E: and the F:, so the
screen should show:
> Drive E:= Driver MSCD001 UNIT 0
> Drive F:= Driver MSCD001 UNIT 1
> Your CD-ROM Is Drive E
(Don't worry that you didn't also see a further line "Your CD-ROM Is Drive
F" - you won't, it will only show the one)
When the boot disk finally settles down, you will be presented with an A:\>
prompt.
Now put a (data) CD into the first CD-ROM and at the A:\> prompt, type "E:"
(no quotes and note the colon after the letter E) Then Press Return.
Now, at the E:\> prompt, type "DIR /P" (no quotes and note the space) Then
press Return.
You should see a listing of the CD contents. - Try several CD's
Try again with the (data) CD's in the other drive, this time typing "F:" at
the "E:\>" prompt to change drives and at the F:\> prompt type "DIR /P" for
the listing.
Come back with your results. Give EXACT errors reports - if any.
Mart
G
Guest
Guest
In addition I thought part of the problem was an inability to write to CDs
yet to date I have seen nothing to suggest that the OP has reinstalled
their CD mastering or packet writing software.
Mike Maltby
mike.maltby@gmail.com
Mart <mart(NoSpam)@nospam.nospam> wrote:
> jclmusic wrote ...
>> messed it
> <snipped>
> prove that your PC will recognise AND read (all) your CD's.
> fitted (CD reader and CD reader/writer) in the computer - but if only
> one device, amend accordingly :-
> (floppy) Disk in the A: drive.
> which should report a drive letter for each of the CD-ROM's - but
> note that they may not necessarily the same letter as you would
> so the screen should show:
> Drive F" - you won't, it will only show the one)
> an A:\> prompt.
> type "E:" (no quotes and note the colon after the letter E) Then
> Press Return.
> Then press Return.
> "F:" at the "E:\>" prompt to change drives and at the F:\> prompt
> type "DIR /P" for the listing.
> Mart
G
Guest
Guest
Indeed, Mike, the OP even refers to "many different cd writing programs i
try." In fact the original post stated :-
> .... i can't load any cds in windows from the cd drive, and my
and later, went on to say :-
> ...: i just tried some other cds. some of them work n i managed 2 install
> programs i try, none of them work tho! :(
But since then, there have been one or two more 'amendments'. The mention of
Linux didn't appear until jcl's fourth post, further increasing Heather's
frustration, I guess <g>
Maybe a re-statement of the issue - with a re-appraisal of the facts - would
help?
Mart
"Mike M" <No_Spam@Corned_Beef.Only> wrote in message
news:OaEe3Y5nFHA.3288@TK2MSFTNGP09.phx.gbl...
> Mike Maltby
>> jclmusic wrote ...
>>> messed it
>> <snipped>
>> an A:\> prompt.
>> Press Return.
>> Then press Return.
>> Mart
Heather
475
>>further increasing Heather's frustration, I guess <g>
LOL!! You noticed that, did you?
I certainly think that the OP should get his *ducks in a row* before
attempting to explain it more......and still take the durned computer to a
tech. He is only going to screw it up further, simply because he can't tell
us what is wrong and what might be causing it.
Sigh......Ms. Tezztee.
"Mart" <mart(NoSpam)@nospam.nospam> wrote in message
news:%23I64Qx5nFHA.708@TK2MSFTNGP09.phx.gbl...
install
of
would
> help?
> Mart
CDs
> > Mike Maltby
> >> jclmusic wrote ...
> >>> messed it
> >> <snipped>
> >> an A:\> prompt.
> >> Press Return.
> >> Then press Return.
> >> Mart
Heather
475
Harry.....what part of the following message went over your head??
He distinctly states that *my cd drive has stopped working*, etc. That is
the information that most of us were acting on. No mention of
Linux......not until way later. And as I had EXACTLY the same CD drive
problem two weeks ago, I gave him the information on how to fix it.
HF
device manager. however, in device manager, it says udnerneath 'this device
is not working properly'. i can't load any cds in windows from the cd drive,
and my cd burning software does not recognise it, so i can't burn cds. what
should i do?<<<<<
news:e%23GYn06nFHA.3108@TK2MSFTNGP10.phx.gbl...
> Heather:
my
question
> Let's wait and see.
> Harry.
> checked
> > out.
> > Heather
> > > jclmusic:
old
> > > one.
> > > Harry.
> > > device
> is
> > > not
drive,
> > and
> > > my
> > > should i
> > > > do?
G
Guest
Guest
H:
Time to get your definition files!
H.
news:%23BE5nODoFHA.3380@TK2MSFTNGP12.phx.gbl...
> HF
device
drive,
what
> should i do?<<<<<
> > Heather:
in
> my
> question
> > Let's wait and see.
> > Harry.
> > checked
> > > out.
> > > Heather
> > > > jclmusic:
> old
> > > > one.
> > > > Harry.
and
> > > > device
device
> > is
> > > > not
> drive,
> > > and
> > > > my
what
> > > > should i
> > > > > do?
