problems with csrss.exe
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
everytime I start windows I get several error messages.
the first one says something like
"the file csrss.exe is not able to run in win32 mode"
and I get about 4 or five others that say something like
"the file csrss.exe specified in the registry is not found where it's
supposed to be"
This is very annoying and seems important.
It doesn't seem to have caused any problems other than the messages.
What can I do to fix this other than re-installing windows?
From: "Heliostrapolis" <Heliostrapolis@discussions.microsoft.com>
| supposed to be"
There are viral and non-viral malware that use that name and can cause problems.
For non-viral malware...
Please download, install and update the following software...
Ad-aware SE v1.06
http://www.lavasoft.de/
http://www.lavasoftusa.com/
SpyBot Search and Destroy v1.4
http://security.kolla.de/
After the software is updated, I suggest scanning the system in Safe Mode.
For viral malware...
Download MULTI_AV.EXE from the URL --
http://www.ik-cs.com/programs/virtools/Multi_AV.exe
It is a self-extracting ZIP file that contains the Kixtart Script Interpreter {
http://kixtart.org Kixtart is CareWare } three batch files, five Kixtart scripts, one Link
(.LNK) file, a PDF instruction file and two utilities; UNZIP.EXE and WGET.EXE. It will
simplify the process of using; Sophos, Trend and McAfee Anti Virus Command Line Scanners to
remove viruses, Trojans and various other malware.
C:\AV-CLS\StartMenu.BAT -- { or Double-click on 'Start Menu' in C:\AV-CLS}
This will bring up the initial menu of choices and should be executed in Normal Mode. This
way all the components can be downloaded from each AV vendor’s web site.
The choices are; Sophos, Trend, McAfee, Exit the menu and Reboot the PC.
You can choose to go to each menu item and just download the needed files or you can
download the files and perform a scan in Normal Mode. Once you have downloaded the files
needed for each scanner you want to use, you should reboot the PC into Safe Mode [F8 key
during boot] and re-run the menu again and choose which scanner you want to run in Safe
Mode. It is suggested to run the scanners in both Safe Mode and Normal Mode.
When the menu is displayed hitting 'H' or 'h' will bring up a more comprehensive PDF help
file.
To use this utility, perform the following...
Execute; Multi_AV.exe { Note: You must use the default folder C:\AV-CLS }
Choose; Unzip
Choose; Close
Execute; C:\AV-CLS\StartMenu.BAT
{ or Double-click on 'Start Menu' in C:\AV-CLS }
NOTE: You may have to disable your software FireWall or allow WGET.EXE to go through your
FireWall to allow it to download the needed AV vendor related files.
* * * Please report back your results * * *
Dave
http://www.claymania.com/removal-trojan-adware.html
http://www.ik-cs.com/got-a-virus.htm
