Problems with dual monitor DVI-D + Displayport
Cerinor
Hey all
Ive been running with dual monitors for some time now, on my old gtx770 with 2x DVI-D and it worked fine. Now i got a new GTX1060 which only have 1 DVI-D port. So i ordered a displayport cable to use on my main monitor (ASUS VG248QE) my second monitor (Samsung Syncmaster P2270) dosnt have displayport, so iam using the DVI-D cable on that one.
I plugged in the display port, turned on the computer, and to my surprise only the second monitor was showing an image. My main monitor said DisplayPort NO SIGNAL.
I then followed some guides i found in here, and tryed a bunch of stuff like turning off monitors, and unpluggin everything, changing ports on GFX card, even tryed the suggestion in this post http://www.tomshardware.co.uk/forum/id-2715055/asus-vg248qe-display-port-dvi-work.html
But it turned out that changing displayport slot on GFX card did the trick, or atleast got an image on my main screen, but now i cant get an image on my second monitor. Iam abit clueless what to do, because as far as i know DVI-D + displayport should work fine together?
Anyone have an idea how i can get both my monitors to display an image? :)
