problems with fifa 2005
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.sports (More info?)
hi I have installed the game and, I have meet all of the requirements
(2500 XP barthon, 512 MB ram, geforce 4, direct X 9.0c,...) I have
installed the game, and all is fine in the beginning, but when I go to
play I can see only the lower 2/3 of the screen normaly the upper 1/3
of the screen I can see only the playing feeld and there are invisible
players, I have the latest drivers and updated every thing, but I
canno't pinpoint the problem, I have haflife, cod, underground2, and
they work all fine,
Do you think that it could be something wrong with the IRQ conflicts,
because the graphic card is sharing its IRQ with lan.
Thanks! Davor
I dont have the game, but are you using the same resolution as your desktop?
Is vsync <in game> on or off? If you have updated all your drivers i'm
thinking it might be an in game setting.
Jamie
Real integrity is doing the right thing, knowing that nobody's going to know
whether you did it or not.
....O.W.
Don't worry about people stealing your ideas. If your ideas are any good,
you'll have to ram them down people's throats
....Howard Aiken
"llc-lj" <llc-lj@hotmail.com> wrote in message
news:8b7f547f.0503051005.7a8fed98@posting.google.com...
> they work all fine,
> Thanks! Davor
>they work all fine,
>Thanks! Davor
Sounds like the refresh rate is not set for the res the game is using.
Go into the game options and set the res to something else then try
again. Are you using XP? You may need to lock your refresh rates. You
can do this a number of ways but for now run "dxdiag" and go to the
More Help tab, go to override and set an override value of say 85hz.
Now all your D3D games will use 85hz as it's refresh rate at all
resolutions.
