I'm relatively new to pc building. Built this rig in february with a hand-me-down-gpu until I could afford to upgrade. Just bought a Gigabyte Geforce RTX 2080 Gaming OC White 8G. I've been lurking on the forums here whenever I had problems and always found answers so I figured I'd ask around.
Build:
i5 9600K
Gigabyte Aorus Ultra z390 Mobo
Corsair Vengeance LPX 16gb
Boot Drive is Crucial Mx250GB M.2-2280
Also Samsung Evo 500 + WD 1TB
Gigabyte GeForce RTX 2080 8 GB GAMING OC WHITE Video Card
Corsair RMx White 850 W 80+ Gold Certified Fully Modular ATX Power Supply
(full build here )
Everything works fine until attempting to game or stress test. Then I either get a LOT of pink artifacts or a freeze/crash.
System was running fine before I put the new GPU in, nothing else has changed. I reseated everything and checked cables, used DDU to uninstall video drivers in safe mode, reinstalled fresh (both studio and game ready) and still am encountering the same situation.
There are logs from both GPU-Z and HWinfo64 here: https://drive.google.com/drive/folders/1mtGynlRBzGmVZfcOtrXqpdLvlkZh3npi?usp=sharing.
A "WhoCrashed" report provides this information:
On Sun 6/9/2019 10:39:37 AM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\060919-9359-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1BC8A0)
Bugcheck code: 0x133 (0x0, 0x501, 0x500, 0xFFFFF8054996E350)
Error: DPC_WATCHDOG_VIOLATION
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above. This could be caused by either a non-responding driver or non-responding hardware. This bug check can also occur because of overheated CPUs (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x1de958)
file path: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5ad622f7ea43f50a\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 430.86
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 430.86
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 430.86 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation DPC_WATCHDOG_VIOLATION
Build:
i5 9600K
(full build here )
