I recently put an EVGA GTX 460 in my rig. I have a Thermaltake TR2 430W power supply and it only has 1 PCIe power plug so i bought a molex to PCIe adapter on DealExtreme. Ever since I installed the new graphics card my computer wont run for more than 5 minutes or sometimes 15 if I get lucky. There are no dramatic effects involved, everything simply just stops. Like a freeze frame/screenshot on my monitor. No BSOD or anything. Happened five f#&%@!ng times during the time I tried to type and post this! Seemed to do it more as I was applying the finishing touches on this post in Firefox, so I'm back in Wordpad. Also every time I start up the computer the graphics card makes a high-pitched sound (kind of like when starting a minigun) for a few seconds- I'm assuming this is normal for this GPU since it goes away after like 2 seconds and runs fine. Also this happens less frequently, but I've had the computer crash before by the screen flickering and going black and the computer resetting itself, graphics card making that noise and everything, but never being able to actually boot. I haven't had time to play many games recently, but I tried Saints Row 3 maxed out and had no problems. Otherwise, the only times I had my computer freeze on me was while on the desktop or browsing the internet or something like that - nothing really graphics-dependent. I've followed the steps in this guide to wipe drivers and try to install some older ones, and there was no difference. I haven't had any overheating issues with it either. Current temp is 40C according to SpeedFan, which seems to be the average while not doing anything graphics-intensive.
I'm wondering if these issues I'm having might be because of the graphics card itself or because I'm using it with a cheap quality adapter, or my PSU just doesn't have enough power. Also, is there some diagnostic I could run to help determine the problem by any chance? Any help would be greatly appreciated.
Thanks,
Daniel
Thanks,
Daniel
