Problems with HD4870
ALPRAS
55
Hello there! (you people must be really tired of me :p)
So, I recently bought a new Corsair CX500 psu to my computer.
I had some problems putting it to work, but in the end everything went fine.
But now there's a problem...
Every time I try to play, the graphic card makes a huge noise, the screen turns off, pc crashes, and then reboots (It happened in Age of Conan). And it is not during gameplay, its in the menu... But earlier, I played Just Cause 2 and there were no problems. The first time it happened was when I was installing the Orange Box with the DVD player. I wasn't even playing at that time... Some time earlier, I wanted to use the DVD player, but I noticed that I had forgotten to plug it to the motherboard and psu. These weird stuff just started to happen after I plugged the DVD player. Still, I unplugged the dvd player, but the same stuff happened.
I don't know what's the problem, the DVD player, the graphic card or the new psu...
Here's my specs:
PSU: Corsair CX500
MoBo: Asus P5K SE
Graph: ATI Radeon HD4870 512MB
Mem: Kingston 4 GB RAM
Processor: Intel Core 2 Duo E2200 2.2Ghz
Hard Drive: Western Digital 500GB
ALPRAS
55
The other psu that I have is a EuroTech Silent Pro 420w, it isnt powerful enough to handle the graphic card :/
Aug 13, 2012
1,349
The only thing I can think of now is diagnosing and making sure that all your other parts are stable, CPU, RAM, etc. By the way you said it isn't powerful enough to handle the card. So did you just buy it and switch out the PSU?
ALPRAS
55
Well... Pretty much yes.
I just switched the 420w psu for a 500w one.
Did I did something I should not have done?
ALPRAS
55
Ok, so I opened the computer (for the millionth time) to see the status of the graphic card while the computer is working.
First, when I turn on the pc, the GC fan does a huge noise (that that huge, but you can hear it pretty well), but it stops some seconds later. The fan doesn't stop working, but the noise just disappears, completely. But about a minute or two later, the fan starts working again with that huge noise and that's when the pc crashes. But when it crashes, the GC fan doesn't stop working... So I don't know if it is a GC problem or its another thing...
