Problems with HDD LED Cable
Neeliyo
244
Hey so I'm almost done building my new computer an I ran into a new problem. I can't seem to find the HDD LED cable in my fractal define R4. I have checked my entire case and I don't know if it come with my case or what. Also I don't know where the cables that are connected to the fan controller go. One of them is a molex cable and the other 3 are two pin connectors.
Thanks for any help.
on page 1-29 they tell that the board have her own hdd led and work wwhen a drive is plug to her ,and on page 1 -44 all the other connector this means the extra one from the case wont be needed to be plug .
No on the motherboard there are two spots for an HDD LED cable but my case came with none. The molex cable doesn't fit in my PSU (XFX Black Edition) and it wasn't long enough.
There is cable for the HDD called HDD LED. Apparently it indicates whether a drive is transferring data.
I don't think you understand what talking about. I am missing the cable. If you look at this picture it shows the HDD LED.
Im using an Asus Maximus Hero. I don't have a single led cable.
Ok thanks that makes me a lot more confident thank you for your help. I just thought it was odd that my case didn't come with the cable but I guess its not too important.
