Question Problems with headphones aukey EP-B36
Oct 25, 2020
Hello, I bought AUKEY Bluetooth headphones model EP-B36-EU-BLACK-FD on Amazon, these headphones has two modes of use, bluetooth and wired. When I use the wired mode, I can only hear the sound, but the microphone doesn't works. I think the problem is that my pc has two connections, one for the audio and one for the microphone, and the headphones has only one cable. To solve the problem I bought an adapter that allows you to connect the microphone connection, but still does not work. The adapter is not broken, because while using it, I can hear the sound.
I have too another problem, with the bluetooth mode. If I use the headphones with two program opened, like spotify and a game, or something else, I cant hear nothing, the Bluetooth mode works only with only one applicazion opened, this problem there is not with the wired mode.
Can I solve these problems or should I proceed with the return of the product? Thank you!
SteveRX4
Notable
BANNED
Sep 29, 2020
1,477
135
890
20
I'd get another headset. You should get various connectors with most good headsets. Mine has a usb connector a 3.5 double connector and a 2x 3.5mm connector.
Oct 25, 2020
Which headphones do you recommend? I would like wired headphones (to avoid bluetooth problems) that are not too bulky and have a built-in microphone, and maybe an adapter already provided with the headphones for my pc with two connections.
hang-the-9
First thing, did you get the correct adapter? You would need a 4 pole to dual 3 pole adapter, and there are quite a few ones that are just faulty which means you may need to try two of them to make sure it's that and not the headphones. My favorite under $100 headset is the Cooler Master MH-751, comfortable, closed back and great even sound. There are other good models but I think the CM MH-751 is the best overall for comfort and sound quality. HyperX Cloud is good, but not as comfortable (heavier, not as soft feeling), sound is a bit more "fun" though with a deeper bass presence. For cheaper ones the SteelSeries Arctis 3 are good.
