M mikepm Distinguished Mar 27, 2011 5 0 18,510 Mar 27, 2011 #1 Hello, I have a DV9000 and had to have chipset replaced. Now, if I try to download anything to my computer, even virus software, it makes the screen go crazy and locks up. I can't even go to get updates. I'm wonderingif anyone has a solution.
G Guest Guest Mar 28, 2011 #2 Who "replaced the chipset"? (Pretty hard to do since it's soldered on the motherboard.) Do you try reloading Windows? Upvote 0 Downvote
hang-the-9 Titan Mar 25, 2010 60,387 1,081 152,940 Mar 28, 2011 #3 Sounds like whoever replaced the parts either did not do a good job or did not load all of the drivers on it. Check with them first. Upvote 0 Downvote
M mikepm Distinguished Mar 27, 2011 5 0 18,510 Mar 29, 2011 #4 Who "replaced the chipset"? (Pretty hard to do since it's soldered on the motherboard.) Do you try reloading Windows? Click to expand... I took it to a computer repair shop and he did solder it. He's researching to see why it might be doing this. Upvote 0 Downvote
mibix19 Distinguished Feb 8, 2010 1,191 0 19,660 Mar 30, 2011 #5 Sounds like he has fried something Upvote 0 Downvote
