Question Problems with i9 9900k, Z390 AORUS XTREME getting whea uncorrectble error.
Jun 2, 2019
System:
Cpu: Intel® Core i9-9900K, 3.6 GHz (5,0 GHz Turbo Boost)
MB: GIGABYTE AORUS Z390 AORUS XTREME
Cpu cooler: Corsair Hydro Series H150i PRO
Gpu: nvidia 1080
Psu: Corsair HX1000i
Ssd: Samsung 860 PRO
The issue: At the end of a fresh install from an iso usb with windows 10 pro. i get a Bsod with whea uncorrectble error. after the "forced reboot" it looks like windows did install but upon opening windows i cant install any drivers without it freezing.
<programs starts up and freezes halfway in the installation>
What i tried so far is too reinstall windows on a different Ssd had the exact same issues bsod on the end of the windows installation and same issues with the windows driver.
and i flashed the bios to F5 version but no improvement.
Is it a doa cpu or motherboard or is it cpu voltage issue? I heard there were issues with the voltage but i have no experience with under/over clocking pc parts.
Hope thats someone can help me with this.
ty for your time, Chris
trying to test the cpu today using Prime95
i also will test the memory with memtest
How long should i keep these test running?
while doing the prime95 i got a bsod with the irql not less or equal error let me see if i can get the dump.
{edited}
reseted the bios to factory
testing it a second time with prime95 to see if it occurs again.
been running it for 15 min no bsod yet. not like the first test that it occurred in the first 5 min.
