Problems with Intel HD 630
bioticboss
6
Hello and I apologize for the lengthy inquiry, but I thought it was better for me to be as detailed as possible:
I am currently using a a pentium G4620 that has the hd 630 integrated GPU, and as the title indicates, after over a week since I built my PC the screen would go black indefinitely even if I moved the mouse or pressed any buttons on the keyboard after the regular 10 mins of inactivity, the trick to get it back to show image was to turn on and off the screen and it would work again, also whenever I try to set a custom resolution so that the image fits my screen (I can't see half the taskbar because of it) the screen goes black and the mouse pointer starts flickering, the only solution to fixing that being to manually reset the PC, and also sometimes when I'm playing Skyrim the game will freeze for 5 secs and an error message saying that intel hd graphics crashed and recovered would show up, and today things escalated bad enough for me to seek help here, I frequently unplug the HDMI cable from my PC to connect it to my laptop so I can watch series on the TV and when I plugged it back on today, I would get no image, I wouldn't even get the AsRock logo when I turned on the computer, so after several failed attempts I decided to tamper with the CPU, and I removed it from the socket and put it back in, and when I turned the computer back on it was giving signal to my screen again, so my question is, what is wrong with my computer? I thought it was related to drivers but now I'm not so sure anymore, if anyone knows I'd really appreciate some help
Thanks.
