I just did a reinstallation of Windows XP Professional. Now I can only connect the modem using the USB cable, but not the Ethernet cable. According to the instructions, I should just have to restart the computer and I should get a "found new hardware" message and then I would be ready to go. Now when I use the Ethernet cable, the network and the modem don't show up. It worked prior to the XP reinstall. I still need to reconnect the router, but I've got to get the cable modem working correctly first.
I already tried the Linksys online support without any help. Any advice would be greatly appreciated.
I have the network settings to "obtain an IP address automatically", "obtain DNS server address atuomatically".
The LAN settings as follows are all unchecked:
Auto detect setting
Use auto configuration script
Use a proxy server for your LAN
My ISP is Comcast.
Thank you in advance,
IZ
Auto detect setting
My ISP is Comcast.
IZ
