Hi to all,
I have some problems with MSI Afterburner!
It doesn't show the GPU temp in its main window,and it is showing 405 MHz for the base core clock all of the time,instead of the normal 135 MHz,all this while idling!
If I open some programs,it starts showing the GPU temp in its main window,and the 135 MHz for the base core clock!
While gaming it shows GPU clocks and temp normally.
Please help me to fix the issues,so it start showing the GPU temp,and the normal base core clock ,without need of opening of another programs or apps!
Edit: Now at the moment it shows the GPU temp and the 135 MHz clock,without any need of running any program! Really weird...
Please help me!
thanks to all in advance!
Best regards!
Please help me!
Best regards!
