Question Problems with Mushkin SSD, is it dead ?
UnicornU
91
Mushkin SDD(MKNSSDEC120G) probably dead -BIOS sees 120GB, gparted sees 15GB, and nothing can be written to it -anything I can do to fix it ?
I have had it for probably like 5 years or so ...not sure how long these SSD last in general
This one died after a circuit breaker tripped ...that circuit failed a number of times in the past but ...this time the drive died
is there anything I can do to resuscitate it ?
RealBeast
Do a secure erase (or a diskpart clean all, which does the same thing).
Some motherboards, seems like most now, have a tools tab in the bios that has a secure erase ability. Just be sure to erase the correct drive.
Otherwise you can easily do it in a command prompt window:
diskpart
list disk
select disk n (the bad drive from the results of the list above)
clean all
exit
Then you can reinitialize and format if the drive is recovered.
