problems with mx 440
halem111
177
my sisters comp has an amd 1800 with SIS 750 mobo and 512 sdram. I decided to put my old mx440 in it thinking it will improve the comp a bit due to the mobo having onboard graphics. so i stuck it in loaded comp up and loaded the drivers, then restarted (with monitor cable in mx440 slot) and it loads fine up until windows loads it starts to load the desktop but then the mouse freezes and the keyboard. however when the mx440 is removed and the monitor cable put back in the SIS mobo graphics slot its fine.
neone know wats goin on?
athlon 2500
512mb corsair xms 3200
radeon 9800np
80 gig hd
Check in your BIOS if you can disable the on-board graphics and things like that!
Have you removed the SIS Video drivers first?
It's tricky to use words like <b><font color=green>AMD</font color=green></b> or <b><font color=blue>Intel</font color=blue></b> in a signature some users could think your are biased.
it disables itself in bios when the other one is installed. i have unistalled the sis drivers for the vga.
athlon 2500
radeon 9800np
80 gig hd
A clean windows installation would probly fix it...
Asus P4P800DX, P4C 2.6ghz@3.25ghz, 2X512 OCZ PC4000 3-3-3-8, Leadtek FX5900 w/ FX5950U bios@500/1000, 2X30gig Raid0
Did you uninstall the old graphics drivers before installing the MX440? Even though they are integrated, I am pretty sure that the graphics part has its own driver set.
<font color=blue> "Trying is the first step towards failure." </font color=blue>
ye i uninstalled the drivers. i jus cant understand why it crashes for. I mean i can stick it in and not install the drivers and it works fine but the res and amount of colours are limited, and its only once i install the drivers to it that it crashes.
athlon 2500
radeon 9800np
80 gig hd
what drivers are you using? I've heard that some of the newer drivers don't work well with the older GF4 cards. I've stuck with some older drivers on mine and haven't had a problem yet.
GA-7VT600-L MOBO
Athlon XP 1600+
RAM 1Gb Kingston PC2700
GF4 MX440 64Mb DDR
120Gb Samsung 7200 RPM
60Gb Maxtor 5400RPM
Fortissimo III
Logitech Z640's
WinXP Home
