Problems With My Custom PC
Annier_yo
Commendable
Apr 12, 2016
12
My PC specs:
CPU: AMD FX 6100 (6 cores)
Motherboard:Gigabyte GA-78LMT-USB3
GPU: MSI GTX 960 Gaming 2gb
PSU: thermaltake smart 650w 80 plus bronze
Storage: 2 tb (4 hardrives)
CPU cooling: Cooler Master Hyper 212 Evo Air
My problems are:
Windows stops my GPU because it has reported problems. (Code 43), I have to turn off PC,unplug and plug GPU again for multiple times until it works again.
Sometimes when I turn on my PC the screen has green vertical lines all over the monitor.
PC turns off randomly and windows says that there was an unexpected shutdown.
I have my GPU drivers up to date, the monitor is in good condition, cables from PC to Monitor are plugged correctly, I have windows updates installed.
I already changed the psu to see if that was the problem, but i still had the same problems and nothing changed.
