Question Problems with my first new build ?
Dec 30, 2023
13
Please keep it to 1 thread.
This js my first time building a pc here my specs
Amd ryzen 5 5600x
XFX SPEEDSTER SWFT 210 Radeon RX 6600 8GB
MSI PRO B550M PRO-VDH WIFI
Team T-Force Delta RGB 16GB (2 x 8GB)
ASUS TUF GAMING 450W Bronze PSU,
Corsair 4000D Airflow
According to the debug led its the ram everything is clicked in and the ram is rgb and the rgb lights up and everything but the debug lag still lights up on the ram any tips or something that will help
Also i already did the bios update i hope idk how to check
Try with a single stick of ram in the second slot. If you can access bios, enable xmp profile and then boot again with 2 sticks.
I see that the mobo has bios flash without cpu. How did you confirm that the bios flash is successful? Any led indications for a sucessful bios flash? Did you rename the .rom file as MSI.rom?
Bios version was the latest one?
Version
7C95v2I
Release Date
2023-10-12
Version
7C95v2I
Release Date
2023-10-12
So at first before i put all the pc parts i did the bios flashback so i got a 32g drive and plugged it in and according to pcparpicker i had to download v25 but now im just realizing that i only put the ryzen 5 5600 x and the mob in the website and now i put all the pcparts in the website and gives me a different version (v-28) , yes i put msi.rom no caps for the msi , i tried taking out the battery 5 min cooldown then do the bios flashback again by pressing the button then wait another 5 mins and still i see the debug led on the ram ( keep in mind im doing this without a display or nothing just the bios button in the back ) i been trying for the past 6 hours trying to figure out something , all the parts are new got them 2 days ago
try the other wifi drivers maybe? MSI website does not mention which wifi device it is using in the board. I thought it would be a standard intel wifi.
its just AMD wifi and intel wifi driver that are listed in the webpage. it should be one of the 2. try installing both in the PC.
Yea it was the amd one
Reactions: Lucky_SLS
MSI Center will do that for you. You have the option to check for system updates in that app.
Or, you can manually install the latest BIOS with the USB inside bios
View: https://www.youtube.com/watch?v=sKMub20CUNI
It showed me in the live update i can download some stuff so i did but i dont think it has nothing to do with how can i plug in the other ram stick and are you sure i can download the latest bios update without no problems???
You would have to be more specific on what stuff it is showing for download.
Do you see the BIOS file name in the available list? If so, it should be all take place with as simple as a click update button.
And the list is verified and checked from MSI, so it wont break your bios again, if thats what you are worried about.
Nothing about bios only bluetooth BUT as im typing this i went to advanced update on mis center and see MB BIOS MS-7c95 should i download it ??? Or just stick to the good old drive bc now people saying that its better with the drive :/
it is not showing the version ?
But anyway, it will show only if an update is available. And you are using v-29 version from Jan 2022. So yes, please update.
Nah it just shows that then current ver 2.90 then online ver 2.10 but do you think updating to the latest bios will let me put the other ram stick no problemo ? Nope still wont boot up with two sticks bios went update went smooth
Amd ryzen 5 5600x
The only problem im facing right now is the 2 ram sticks i know im supposed to put it in slot 2 then 4 but the pc only boots up when theres a ram only on slot 2 and when i try to put slot 4 it get a debug led on the dram ( btw there both rgb both came in 1 packet and when i put the ram on the 4 slot the rgb lights uo and everything the only problem is the pc dosent boot up . HEEEELp
If you are putting the pair in A2 and B2 as shown in your manual and are not booting, did you try both sticks individually in A2 and do they both work?
Is the memory listed in the compatibility list HERE, you didn't list the full model so you will need to check that out. You can find it most quickly by putting the model number in the search box.
If yes to all of the above you might want to boot with one stick and check the bios number and update if needed. Otherwise contact support for an RMA if nothing else works.
Reactions: PEnns
both of the rams work they both light up once connected and turned on but only shows debug led on cpu then yellowish on dram but when i put the one that worked on A2 (also works on b2 but it says fail to overclock or something like that because i over clocked it on A2 then only gives me the option to go to bios) it works fine can boot up windows and everything i really really think its a bios setting any ideas ?
Also this is the memory model TF4D416G3600HC18JDC01
It is compatible i hope
450W Bronze PSU and GPU needs 550W PSU would not try and overclock your system at the moment also is the bios got the lastest update?
Yea latest update ima go back to normal 2400 mhz then but still cant figure out why the pc can boot up with this one and not the other one they both work
